03-08-2018 07:29 PM - edited 03-12-2019 05:05 AM
Hello everybody,
I have a follow problem , I have an ASA with public IP where I run anyconnect , it working fine ,, but the problem is that my ISP say me that they are seeing my IP PRIVATES in the range public that they give me .
and the ip privates are of my VPN'pools ,.
Do you have any idea why my ISP see my IP privates ? there is any problem with the anyconnect config??
Thanks.
Solved! Go to Solution.
03-12-2018 10:02 AM
03-12-2018 02:38 AM - edited 03-21-2018 08:41 AM
03-12-2018 09:24 AM
Why routing ??
and not natting?
03-12-2018 09:26 AM
I am not denying to say that there will no issue with NAT but it could be a reason for routing also. That's why I was asked for configuration.
Deepak Kumar
03-12-2018 08:32 AM
03-12-2018 09:22 AM
Yes, all traffic going over anyconnect , I have a lot of rules of NoNat , maybe some rule is missing , what do you think?
03-12-2018 10:02 AM
03-12-2018 11:16 AM
03-21-2018 08:39 AM
Hello I think I have a problem with no-proxy-arp because the ISP see my ip private addresses (of VPN's pools) with the mac of my FW , I applied no-proxy-arp in all nat rules but the problem persist.
