Anyconnect SSL VPN Problem
shen dong
Hi there,
some Anyconnect Users experience frequent disconnects:
Oct  9 14:10:08 fw : %ASA-4-113019: Group = A, Username = W, IP = a.b.c.d, Session disconnected. Session Type: SSL, Duration: 0h:03m:44s, Bytes xmt: 555379, Bytes rcv: 479046, Reason: Connection Preempted
Oct  9 14:14:49 fw : %ASA-4-113019: Group = A, Username = W, IP = a.b.c.d, Session disconnected. Session Type: SSL, Duration: 0h:04m:41s, Bytes xmt: 705887, Bytes rcv: 586615, Reason: Connection Preempted
Oct  9 14:26:18 fw : %ASA-4-113019: Group = A, Username = W, IP = a.b.c.d, Session disconnected. Session Type: SSL, Duration: 0h:11m:29s, Bytes xmt: 660791, Bytes rcv: 653513, Reason: Connection Preempted
When placing "ping -t <destination through the tunnel>" the Anyconnect session is not disconnected. The idle timeout is set to 60 min.
Can anyone give me a hint?
thank you .
Software  Versions:
Cisco Anyconnect Secure Mobility Client, Version 3.1.05182
# sh ver
Cisco Adaptive Security Appliance Software Version 9.1(4)
Device Manager Version 7.3(1)101
Compiled on Thu 05-Dec-13 19:37 by builders
System image file is "disk0:/asa914-k8.bin"
Config file at boot was "startup-config"
# up 23 days 9 hours
failover cluster up 1 year 124 days
Hardware:   ASA5520, 2048 MB RAM, CPU Pentium 4 Celeron 2000 MHz,
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xfff00000, 1024KB
Encryption hardware device : Cisco ASA-55xx on-board accelerator (revision 0x0)
                             Boot microcode        : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode     : CNLite-MC-SSLm-PLUS-2_05
                             IPSec microcode       : CNlite-MC-IPSECm-MAIN-2.09
                             Number of accelerators: 1
admin11111
Level 4
Level 4
i have been seeing this issue for two years, with multiple ASA's any resolution?
admin11111
Level 4
Level 4
vpn session is byyond the limit .  Use this command:  vpn-simultaneous-logins 5000
