ASA 5505 first configuration - no connection with external VPN
simonemoretti
Hi!
I'm on my first configuration of a Cisco firewall. I'm trying ASA 5505 using Cisco ASDM 5.2 (not GUI). I configured Vlan1 (inside) and Vlan2(outside) and all seems to work correctly. Network clients can use Internet and ping internal LAN. But I've some problems with vpn and other services: 1. when I try to connect to external VPN server the connection procedure stopped in username/password validation (if I try directly, without firewall ASA, there's no problem) 2.I've problems also to see external security cam working trough a web server.
I open port 1723 - 500 and GRE. What can I do more? Thank's all.
ah! this is Cisco ASDM Syslog error message:
Syslog message
3|Jan 29 2010|10:07:20|305006|88.41.211.232||regular translation creation failed for protocol 47 src inside:192.168.0.2 dst outside:88.41.211.232
Result of the command: "show startup-config"
: Saved
: Written by enable_15 at 18:37:26.964 UTC Thu Jan 28 2010
ASA Version 7.2(4)
hostname ciscoasa
domain-name default.domain.invalid
enable password UqJHTo7.2sANHB7y encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
access-list outside_access_in extended permit tcp any eq pptp 192.168.0.0 255.255.255.0 eq pptp
access-list outside_access_in extended permit udp any eq isakmp 192.168.0.0 255.255.255.0 eq isakmp
access-list outside_access_in extended permit gre any 192.168.0.0 255.255.255.0
access-list outside_access_in extended permit ip any any
access-list outside_access_in extended permit esp any 192.168.0.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd option 3 ip 192.168.0.1
dhcpd option 6 ip 212.216.172.62
dhcpd address 192.168.0.2-192.168.0.129 inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:74d04070ef0b566c8c95e3024c6b6232
amaerklin
Hi Simone
1. if you're using outbound vpn (ipsec) to a headend located in the internet you'll need to open udp 500 for isakmp and udp 4500 for nat-t and IPsec over TCP will be using tcp 10000 if cisco is used.
2. you'll need to add the following to your mpf configuration:
  inspect ipsec-pass-thru
this will guarantee to let you ESP (protocol 50) to pass the ASA, also known as native IPsec.
3. I'm assuming that you have to setup your NAT or PAT stuff in the right manner. Configure your NAT like below, if you want to present an internal server to the outside world:
static (inside,outside) outsideip insideip netmask 255.255.255.255 0 0 -> for static nat
static (inside,outside) interface insideip netmask 255.255.255.255 0 0 -> for static pat
4. use ipsec instead of pptp, since the cisco vpn client is free and much more secure!
hope this helps
cheers
Nico
Thanks, I'll try your solution next Monday. Now I send you two additions:
1. I've configured NAT as dynamic (for future use I'll probably configure static NAT for VPN server)
2. I nedd to connect to evrey PPTP or IPSec external VPN e probably there are not Cisco Router (Dlink, I think)
Bye
Ok, now it works!
I simply add flag on PPTP in Security Policy > Server policy rule > Rule action (when you edit the policy.
Now I try to create a VPN server, so ... I think I'll need more help. Bye
ad.sharma
You have to allow PPTP inspection in your default policy group.
  • myasa(config)#policy-map global_policy
  • myasa(config-pmap)#class inspection_default
  • myasa(config-pmap-c)#inspect pptp
Anadi
