11-18-2014 02:12 AM
Hello!
Already more than a week ago, as we had a new channel of communication from MGTSa (ONT terminal Sercomm RV6688BCM, who just barely made in the "bridge" - was forced to make the provider in order to receive our white Cisco Ip-address), and now I'm trying too much more than a week to raise between our offices firm VPN IKEv1 IPsec Site-to-Site tunnel.
Configurable and use the wizard in ASDM and handles in CLI, the result of one, the connection does not rise.
Version Cisco 9.2 (2), the image of Cisco asa922-k8.bin, version license Security Plus, version ASDM 7.2 (2).
What I'll never know ...
Full configuration and debug enclose below.
Help, what can follow any responses, please! I was quite exhausted!
Config:
Result of the command: "sh run"
: Saved
: Serial Number: XXXXXXXXXXXX
: Hardware: ASA5505, 512 MB RAM, CPU Geode 500 MHz
ASA Version 9.2(2)
hostname gate-71
enable password F6OJ0GOws7WHxeql encrypted
names
ip local pool vpnpool 10.1.72.100-10.1.72.120 mask 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 10.1.72.254 255.255.255.0
interface Vlan2
nameif outside_mgts
security-level 0
ip address 62.112.100.R1 255.255.255.252
ftp mode passive
clock timezone MSK/MSD 3
clock summer-time MSK/MDD recurring last Sun Mar 2:00 last Sun Oct 3:00
dns domain-lookup inside
dns server-group MGTS
name-server 195.34.31.50
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network NET72
subnet 10.1.72.0 255.255.255.0
object network obj-0.0.0.0
host 0.0.0.0
object network Nafanya
host 10.1.72.5
object network obj-10.1.72.0
object network NET61
subnet 10.1.61.0 255.255.255.0
object network NETWORK_OBJ_10.1.72.96_27
subnet 10.1.72.96 255.255.255.224
object network NETT72
object network NET30
subnet 10.1.30.0 255.255.255.0
object network NETWORK_OBJ_10.1.72.0_24
object-group service OG-FROM-INET
service-object icmp echo
service-object icmp echo-reply
service-object icmp traceroute
service-object icmp unreachable
service-object tcp-udp destination eq echo
object-group network DM_INLINE_NETWORK_1
network-object object NET30
network-object object NET72
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
port-object eq https
access-list inside_access_in extended permit ip object NET72 object-group DM_INLINE_NETWORK_1
access-list inside_access_in extended permit ip 10.1.72.0 255.255.255.0 any
access-list inside_access_in extended permit ip object Nafanya any inactive
access-list inside_access_in extended permit object-group OG-FROM-INET any any
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended deny ip any any log alerts
access-list outside_mgts_access_in extended permit object-group OG-FROM-INET any any
access-list outside_mgts_access_in extended permit tcp any any object-group DM_INLINE_TCP_1
access-list outside_mgts_access_in extended deny ip any any log alerts
access-list outside_mgts_cryptomap extended permit ip 10.1.72.0 255.255.255.0 object NET61
access-list VPN-ST_splitTunnelAcl standard permit 10.1.72.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside_mgts 1500
ip verify reverse-path interface outside_mgts
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside_mgts) source static NET72 NET72 destination static NETWORK_OBJ_10.1.72.96_27 NETWORK_OBJ_10.1.72.96_27 no-proxy-arp route-lookup
nat (inside,outside_mgts) source static NETWORK_OBJ_10.1.72.0_24 NETWORK_OBJ_10.1.72.0_24 destination static NET61 NET61 no-proxy-arp route-lookup
nat (inside,outside_mgts) dynamic obj-0.0.0.0
nat (inside,outside_mgts) dynamic interface dns
access-group inside_access_in in interface inside
access-group outside_mgts_access_in in interface outside_mgts
route outside_mgts 0.0.0.0 0.0.0.0 62.112.100.R 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
no user-identity enable
user-identity default-domain LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 10.1.72.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_mgts_map 1 match address outside_mgts_cryptomap
crypto map outside_mgts_map 1 set pfs group1
crypto map outside_mgts_map 1 set peer 91.188.180.42
crypto map outside_mgts_map 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_mgts_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_mgts_map interface outside_mgts
crypto map inside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map interface inside
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
email felix1988@mail.ru
subject-name CN=gate-71
serial-number
ip-address 62.112.100.42
proxy-ldc-issuer
crl configure
crypto ca trustpoint ASDM_TrustPoint1
enrollment self
keypair ASDM_TrustPoint1
crl configure
crypto ca trustpool policy
crypto ca certificate chain ASDM_TrustPoint0
certificate eff26954
30820395 3082027d a0030201 020204ef f2695430 0d06092a 864886f7 0d010105
019
6460ae26 ec5f301d 0603551d 0e041604 14c9a3f2 d70e6789 38fa4b01 465d1964
60ae26ec 5f300d06 092a8648 86f70d01 01050500 03820101 00448753 7baa5c77
62857b65 d05dc91e 3edfabc6 7b3771af bbedee14 673ec67d 3d0c2de4 b7a7ac05
5f203a8c 98ab52cf 076401e5 1a2c6cb9 3f7afcba 52c617a5 644ece10 d6e1fd7d
28b57d8c aaf49023 2037527e 9fcfa218 9883191f 60b221bf a561f2be d6882091
0222b7a3 3880d6ac 49328d1f 2e085b15 6d1c1141 5f850e5c b6cb3e67 0e373591
94a82781 44493217 38097952 003d5552 5c445f1f 92f04039 a23fba20 b9d51b13
f511f311 d1feb2bb 6d056a15 7e63cc1b 1f134677 8124c024 3af56b97 51af8253
486844bc b1954abe 8acd7108 5e4212df 193b8167 db835d76 98ffdb2b 8c8ab915
0db3dd54 c8346b96 c4f4eff7 1e7cd576 a8b1f86e 3b868a6e 89
quit
crypto ca certificate chain ASDM_TrustPoint1
certificate a39a2b54
30820377 3082025f a0030201 020204a3 9a2b5430 0d06092a 864886f7 0d010105
0500304b 3110300e 06035504 03130767 6174652d 36313137 30120603 55040513
c084dcd9 d250e194 abcb3eb8 1da93bd0 fb0dba1a b1c35b43 d547a841 5d4ee1a4
14bdb207 7dd790a4 0cd70471 5f3a896a 07bd56dc ea01b3dd 254cde88 e1490e97
f3e54c05 551adde0 66aa3782 c85880c2 b162ec29 4e49346a df71062d 6d6d8f49
62b9de93 ba07b4f7 a50e77e1 8f54b32b 6627cb27 e982b36f 362973a0 88de3272
9bd6d4d2 8ca1e11f 214f20a9 78bdea95 78fdc45c d6d45674 6acb9bcb d0bd930e
638eedfe cd559ab1 e1205c48 3ee9616f e631db55 e82b623c 434ffdc1 11020301
0001a363 3061300f 0603551d 130101ff 04053003 0101ff30 0e060355 1d0f0101
ff040403 02018630 1f060355 1d230418 30168014 0cea70bf 0d0e0c4b eb34a0b1
8242a549 5183ccf9 301d0603 551d0e04 1604140c ea70bf0d 0e0c4beb 34a0b182
42a54951 83ccf930 0d06092a 864886f7 0d010105 05000382 0101004e 7bfe054a
d434a27c 1d3dce15 529bdc5f 70a2dff1 98975de9 96077966 2a97333b 05a8e9ef
bf320cbd ecec3819 ade20a86 9aeb5bde bd129c7b 29341e4b edf91473 f2bf235d
9aaeae21 a629ccc6 3c79200b b9a89b08 4745a411 bf38afb6 ea56b957 4430f692
34d71fad 588e4e18 2b2d97af b2aae6b9 b6a22350 d031615b 49ea9b9f 2fdd82e6
ebd4dccd df93c17e deceb796 f268abf1 bd5f7b69 89183841 881409b5 f484f0e7
ebf7481c faf69d3e 9d24df6e 9c2b0791 785019f7 a0d20e95 2ef35799 66ffc819
4a77cdf2 c6fb4380 fe94c13c d4261655 7bf3d6ba 6289dc8b f9aad4e1 bd918fb7
32916fe1 477666ab c2a3d591 a84dd435 51711f6e 93e2bd84 89884c
quit
crypto isakmp identity address
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable outside_mgts client-services port 443
crypto ikev2 remote-access trustpoint ASDM_TrustPoint0
crypto ikev1 enable inside
crypto ikev1 enable outside_mgts
crypto ikev1 policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
no ssh stricthostkeycheck
ssh 10.1.72.0 255.255.255.0 inside
ssh timeout 60
ssh key-exchange group dh-group1-sha1
console timeout 0
vpnclient server 91.188.180.X
vpnclient mode network-extension-mode
vpnclient nem-st-autoconnect
vpnclient vpngroup VPN-L2L password *****
vpnclient username aradetskayaL password *****
dhcpd auto_config outside_mgts
dhcpd update dns both override interface inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point ASDM_TrustPoint0 inside
ssl trust-point ASDM_TrustPoint0 outside_mgts
webvpn
enable outside_mgts
group-policy GroupPolicy_91.188.180.X internal
group-policy GroupPolicy_91.188.180.X attributes
vpn-tunnel-protocol ikev1
group-policy VPN-ST internal
group-policy VPN-ST attributes
dns-server value 195.34.31.50 8.8.8.8
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPN-ST_splitTunnelAcl
default-domain none
username aradetskayaL password HR3qeva85hzXT6KK encrypted privilege 15
tunnel-group 91.188.180.X type ipsec-l2l
tunnel-group 91.188.180.X general-attributes
default-group-policy GroupPolicy_91.188.180.42
tunnel-group 91.188.180.X ipsec-attributes
ikev1 pre-shared-key *****
ikev2 remote-authentication pre-shared-key *****
ikev2 remote-authentication certificate
ikev2 local-authentication pre-shared-key *****
tunnel-group VPN-ST type remote-access
tunnel-group VPN-ST general-attributes
address-pool vpnpool
default-group-policy VPN-ST
tunnel-group VPN-ST ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
inspect icmp error
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:212e4f5035793d1c219fed57751983d8
: end
gate-71# sh crypto ca trustpoints
Trustpoint ASDM_TrustPoint0:
Configured for self-signed certificate generation.
Trustpoint ASDM_TrustPoint1:
If you need something more, then lay out!
Please explain why it is I do not want to work?
Solved! Go to Solution.
11-18-2014 02:40 AM
When IPSEC tunnel is not coming up, the first thing comes in to my mind is to run a packet tracer from the CLI and check the phases in it. Please run this command from your side firewall and share the output. i just compiled this command with random ip address and ports in your given range.
packet-tracer input inside tcp 10.1.72.2 1233 10.1.61.2 443 detailed
Best Regards,
Srihari
11-18-2014 02:40 AM
Best Regards,
Srihari
11-18-2014 03:19 AM
When I launched a packet tracer from the CLI connection has gone! Hooray!
I just do not understand why it had not launched with the same settings?
As I understood MGTS finally required ports began to miss!
