07-13-2011 11:54 AM - edited 02-21-2020 05:26 PM
please disregard 158.60.168.0/24 being used as our internal private network
phase 1 and 2 - no problems
vpnclient gets correct ip from pool and dns/etc
traffic will not pass through tunnel.
debug icmp shows something like this when i ping from vpnclient thru asa to lan
ICMP echo request from outside:10.10.10.1 to inside:158.60.168.29 ID=768 seq=2048 len=32
vpnclient statistics shows packets sent incrementing, but packets received won't increment.
vpnclient is 5.x
I have sysopt connection permit-vpn enabled even though show run sysopt doesn't display anything
Thanks in advance!!!!
ASA5510
ASA Version 8.2(1)
hostname ciscoasa
enable password P8mtLTam1zoMz9X6 encrypted
passwd P8mtLTam1zoMz9X6 encrypted
names
interface Ethernet0/0
nameif inside
security-level 100
ip address 158.60.168.2 255.255.255.0
interface Ethernet0/1
nameif outside
security-level 0
ip address a.b.66.14 255.255.255.252
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
nameif management
security-level 100
management-only
boot system disk0:/asa821-k8.bin
ftp mode passive
access-list inside_nat0_outbound extended permit ip 158.60.168.0 255.255.255.0 10.10.10.0 255.255.255.0
access-list outside_access_in extended permit tcp any any eq ssh
access-list vpnclient-splittunnel standard permit 158.60.168.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu management 1500
ip local pool vpnclient-pool 10.10.10.1-10.10.10.254 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-621.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 158.60.168.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 a.b.66.13 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http 158.60.168.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map vpnclient_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic vpnclient_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp ipsec-over-tcp port 10000
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy vpnclient-policy internal
group-policy vpnclient-policy attributes
dns-server value 158.60.168.29
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value vpnclient-splittunnel
username dlindsey password 7U2c32fEqsZtcCv0 encrypted privilege 15
tunnel-group driveline type remote-access
tunnel-group driveline general-attributes
address-pool vpnclient-pool
default-group-policy vpnclient-policy
tunnel-group driveline ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
message-length maximum client auto
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:7e217f15d83ac741ff5e65105c81a42e
: end
07-14-2011 12:22 AM
A couple of things to add:
inspect icmp
management-access inside
Then from the VPN Client, try to see if you can ping the ASA inside interface (158.60.168.2).
If you can, then that's good.
You would need to check the host that you are trying to ping to see if the default gateway is the ASA inside interface (158.60.168.2) and also there is no personal firewall, etc on the host that might be preventing inbound access.
09-30-2011 07:49 AM
I have a similar problem. I have 1 user able to log in to the ipsec-ra VPN using the cisco VPN client and access the servers, but another user is not able to access the servers. Did you manage to solve the problem ? If yes, what did you do ?
