ASA 9.1 Webvpn - URL Entry default protocol selection
Flavio Vettori
Hello all,      through asa webvpn we need to provide our user remote destkop access; we would not use static rdp:// bookmarks for this accomplishmet as this would grow too much management effort with bookmarks updating.  Our strategy would be to give users the "url entry" bar where they can input the resource name (example: "pc-flavio.mydomain") so the management effort is outplaced to the guys who manage the dns server. This stated, we noticed that most end-users would get in troubles because of the default-ing "url-protocol" is http://, so they don't change it to the correct rdp:// from the drop-down list and don't have the java-rdp applet started.  There is a chance to admin the default protocol for URL Entry Functions?  Our setup is asa 5510 ver 9.1, act/stb failover.  Thanks in advance, Flavio
Michael Muenz
Level 5
Level 5
You cannot sort it, the only way is to disable Web Application via customization. But then you will loose all your http bookmarks.
Michael Please rate all helpful posts
Thank you for your reply.
