696
Beginner
ASA L2L VPN problem
hi all,
I have two ASAs:
Cisco Adaptive Security Appliance Software Version 8.4(4)1
Cisco Adaptive Security Appliance Software Version 8.2(2)16
I don't understand why but I can't create the L2L vpn between the two devices.
Logging shows the following errors:
Mar 27 12:40:33 [IKEv1 DEBUG]IP = yyy.yyy.yyy.yyy, IKE SA Proposal # 1, Transform # 4 acceptable  Matches global IKE entry # 1
Mar 28 2013 10:48:23: %ASA-5-713119: Group = yyy.yyy.yyy.yyy, IP = yyy.yyy.yyy.yyy, PHASE 1 COMPLETED
Mar 28 2013 10:48:23: %ASA-5-713904: Group = yyy.yyy.yyy.yyy, IP = yyy.yyy.yyy.yyy, All IPSec SA proposals found unacceptable!
Mar 28 2013 10:48:23: %ASA-3-713902: Group = yyy.yyy.yyy.yyy, IP = yyy.yyy.yyy.yyy, QM FSM error (P2 struct &0xade5b020, mess id 0x5b5ac87e)!
Mar 28 2013 10:48:23: %ASA-3-713902: Group = yyy.yyy.yyy.yyy, IP = yyy.yyy.yyy.yyy, Removing peer from correlator table failed, no match!
Mar 28 2013 10:48:23: %ASA-5-713259: Group = yyy.yyy.yyy.yyy, IP = yyy.yyy.yyy.yyy, Session is being torn down. Reason: Phase 2 Mismatch
Mar 28 2013 10:48:23: %ASA-4-113019: Group = yyy.yyy.yyy.yyy, Username = yyy.yyy.yyy.yyy, IP = yyy.yyy.yyy.yyy, Session disconnected. Session Type: LAN-to-LAN, Duration: 0h:00m:00s, Bytes xmt: 0, Bytes ry: 0, Reason: Phase 2 Mismatch
Mar 28 2013 10:48:23: %ASA-5-713904: IP = yyy.yyy.yyy.yyy, Received encrypted packet with no matching SA, dropping
e:  Mismatched attribute types for class Group Description:  Ry'd: Group 5  Cfg'd: Group 2
Phase two seems correctly configured, but I don’t understand why I get the error shown above.
Below is the configuration on both devices:
access-list VPN_y extended permit ip yyy.yyy.yyy.yyy 255.255.255.192 xxx.xxx.xxx.xxx 255.255.255.0
crypto ipsec ikev1 transform-set ESP-AES-256 esp-aes-256 esp-sha-hmac
crypto map outside_map 10 match address VPN_y
crypto map outside_map 10 set pfs
crypto map outside_map 10 set peer yyy.yyy.yyy.yyy
crypto map outside_map 10 set ikev1 transform-set ESP-AES-256
crypto map outside_map 10 set security-association lifetime seconds 84600
tunnel-group yyy.yyy.yyy.yyy type ipsec-l2l
tunnel-group yyy.yyy.yyy.yyy ipsec-attributes
ikev1 pre-shared-key *****
crypto isakmp identity address
crypto ikev1 enable outside-3
crypto ikev1 policy 4  ---------> MATCH
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 10
encryption 3des
hash md5
group 2
lifetime 86400
crypto ikev1 policy 20
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-256
hash md5
group 2
lifetime 86400
crypto ikev1 policy 60
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption 3des
hash sha
group 5
lifetime 86400
crypto ikev1 policy 80
encryption des
hash md5
group 1
lifetime 86400
crypto ikev1 policy 90
encryption des
hash md5
group 2
lifetime 86400
crypto ikev1 policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
access-list VPN_X extended permit ip yyy.yyy.yyy.yyy 255.255.255.192 xxx.xxx.xxx.xxx 255.255.255.0
crypto ipsec transform-set ESP-AES-256 esp-aes-256 esp-sha-hmac
crypto map outside_map 70 match address VPN_x
crypto map outside_map 70 set pfs
crypto map outside_map 70 set peer xxx.xxx.xxx.xxx
crypto map outside_map 70 set transform-set ESP-AES-256
crypto map outside_map 70 set security-association lifetime seconds 84600
tunnel-group xxx.xxx.xxx.xxx type ipsec-l2l
tunnel-group xxx.xxx.xxx.xxx ipsec-attributes
pre-shared-key **
crypto isakmp enable Internet
crypto isakmp policy 4
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 5
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 8
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 10 ----------> MATCH
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 20
encryption aes-256
hash md5
group 2
lifetime 86400
crypto isakmp policy 30
encryption aes-256
hash sha
group 2
lifetime 28800
crypto isakmp policy 40
encryption 3des
hash md5
group 2
lifetime 28800
crypto isakmp policy 50
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 70
encryption 3des
hash sha
group 5
lifetime 86400
crypto isakmp policy 80
encryption des
hash md5
group 1
lifetime 86400
crypto isakmp policy 90
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp policy 100
encryption aes-256
hash sha
group 2
lifetime 3600
crypto isakmp policy 110
encryption aes-256
hash sha
group 2
lifetime 1440
crypto isakmp policy 130
authentication rsa-sig
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 140
encryption 3des
hash md5
group 2
lifetime 1440
crypto isakmp policy 160
encryption aes-256
hash sha
group 5
lifetime 86400
crypto isakmp policy 170
encryption aes
hash sha
group 2
lifetime 2880
Please let me know how I can solve this issue.
Everyone's tags (3)
4 REPLIES 4
ASA L2L VPN problem
Andrea,
Post full debugs please, looks like you're having problem at phase 2 establishment not phase 1.
BTW your access lists are not mirrored:
Site 1
Site2:
M.
Beginner
Re: ASA L2L VPN problem
Hi Marcin,
thank for reply, in attach you can find a complete debug session.
Beginner
You are referencing the acl VPN_x in the crypto map, which doesn't exist, you have defined VPN_X.
Best regards,
Silla
Highlighted
Beginner
The problem relies on phase 2 so based on the configuration I can see that the ACL for the crypto map the is not matching. Remember that the ACL should be a mirror of each other so let me use this example.
site A:
access-list VPN_y extended permit ip 1.1.1.x 255.255.255.192 2.2.2.0 255.255.255.0
site B:
access-list VPN_y extended permit ip 2.2.2.0 255.255.255.0 1.1.1.x 255.255.255.192
so in your case on the site B you have to reverse the ACL that you have in place. and then try again.
