Community Helping Community
744
Beginner
ASA out interface ip mask /32
Hi All,
Working on configuring ASA , where the ISP assigned outside IP:20.20.20.67/32 and gateway: 20.20.20.69.
This ASA will act as regular NAT device and L2L tunnel to another location.
My question is /32 on outside is good enough tfor doing this config.
Please review and suggest.
Thank you
MS
3 REPLIES 3
Beginner
Re: ASA out interface ip mask /32
I just tried myself.. it is not accepted on ASA5510 interface. Saying 'bad Mask'.
Thank you
MS
Beginner
I suggest you double check with your ISP.
The info you have doesn't make sense.
A 32 bits subnet is a one address subnet , meaning a single host. But your outside interface needs to be in the same subnet than your default gateway. The smallest subnet possible here would be a /30 subnet, wich give 4 addresses (2 usable) .
But .67 and .69 are not part of the same /30 subnet. And .67 would be a broadcast address in a /30 ( 64-65-66-67).
So .67 and .69 can only be part of at least a /29 subnet ( 64-65-66-67-68-69-70)
But you have to verify thisa with your ISP because both devices needs to be configure with the same subnet.
Highlighted
Beginner
/32 mask does not make any sense.
I agree that the mask ideally should be the same in both ends, but they don't need to. The ASA does not use the broadcast address.
Content for Community-Ad
FusionCharts will render here
