Asa SSH access from outside using public ip
ssethu_dce
We have configured the ssh configuration in our ASA firewall, We are able to access the asa firewall through ssh from intranet using outside interface public ip but not able to access the same through public network, even i tried (SSH 0.0.0.0 0.0.0.0 outside)also but no luck.
anyone please help on this.
Sethu.
7 Replies 7
Walter Astori
You must know the public IP address, for example :
ssh 94.125.239.0 255.255.255.0 OUTSIDE
sulloas16
Hi Sethu!
I'm having the exact same issue, did you find the problem?
I'll appreciate your comments.
Steph.
Hello
Please did you find the problem
I want to access my ASA through SSH by using public ip address
Boris Uskov
Level 4
Level 4
Hi, are you able to connect via ssh to inside interface of ASA?
Please, post the whole config.
Hi! Yes I'm able to connect from inside interface. See attached the whole config.
so, I see, that you are getting the IP-address to outside interface from
 ip address pppoe
Could you, please, verify, that the PPPoE ISP doesn't block tcp port 22? It is very easy to do. I need to use packet-capture on ASA.
capture TEST-SSH interface outside match ip host X.X.X.X any
where X.X.X.X - the IP-address, from where you are trying to open SSH-Session
then try show capture TEST-SSH to view capture-buffer.
Hi Boris,
Apparently the issue was from ISP side.
Not really sure of what they did but now it's working fine.
Thanks for your help!
