ASA VPN Load Balancing Questions
jackfait1
The company where I work currently has a Primary/Standby ASA configuration for our employee VPN. However, I have recently set up load balancing in a test lab. For performance reasons, we would like multiple ASAs to share the VPN traffic load. When the ASA that AnyConnect has the tunnel established to, is disconnected, the AnyConnect client sits at connecting till you manually disconnect and then reconnect to the other load balanced ASA. Is this normal or should the AnyConnect client automatically find the other load balanced ASA and reconnect automatically? Is there a way to replicate ASA config in a load balanced setting? Would a combination of load balancing with Primary/Standby be a better solution? I appreciate the input.
The test lab I have ASA 5520s and our main ASAs are 5545-X
Rahul Govindan
This is expected AFAIK. The redirect only happens at the initial connection attempt, when the master redirects the connection to a slave (or itself) based on the load. Once this is done, the connection is essentially between the client and that slave ASA alone. When the disconnect of the ASA happens, the AnyConnect only tries to reconnect to the last connected ASA.
There is no way to config sync among load balanced ASA's. Also you cannot have Active/Standby pair as also load balanced nodes, they would only act as one of the nodes. So you can have 2 pairs of Active/Standby devices which results in 2 nodes in Load balancing.
