04-25-2013 04:39 PM
I have a bit of a strange one - well stange to me at least.
I have a site to site ipsec tunnel setup between an ASA5510 and a 2951 Router. The ASA 5510 is on a 10.x subnet with a few vlans behind it. There are also 7 other ASA5505 that connect to this box with ipsec.
The 2951 is on a 10.x subnet with multiple vlans behind it (10.x and 192.x subnets).
When I had ACL to allow traffic from 10.20.0.0 (ASA) to 192.168.111.0 (2951 - voice vlan) the connection comes online and is stable.
The minute I add any of the following, the connection drops off with Phase 2 errors:
10.20.0.0 to 10.1.200.0
10.20.1.0 to 10.1.1.0
I can add a second 10.20.0.0 to 192.168.10.0 with no problem at all. The issue only seems to occur when attempting to add traffic from 10 to 10 on the tunnel.
Any thoughts or ideas?
04-26-2013 12:57 AM
do you have any logs? try to post the output that gives error meesage regarding phase 2 from debug command. try to nat it and see if that helps, it looks something like this: 10.20.0.0 - x.x.x.x - 10.1.200.0
04-26-2013 03:34 AM
Thanks for the reply. I have tried it with and without NAT. I've gone through the ACL config 1,000 times, so its not a mismatch there and both are set to 3DES-MD5
326612: Apr 25 16:58:51.793: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=10.20.255.106, prot=50, spi=0x6779E85B(1736042587), srcaddr=10.20.120.46
326613: Apr 25 16:58:51.801: ISAKMP (0): received packet from 44.33.11.74 dport 500 sport 500 Global (I) MM_SA_SETUP
326614: Apr 25 16:58:51.801: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
326615: Apr 25 16:58:51.801: ISAKMP:(0):Old State = IKE_I_MM3 New State = IKE_I_MM4
326616: Apr 25 16:58:51.805: ISAKMP:(0): processing KE payload. message ID = 0
326617: Apr 25 16:58:51.833: ISAKMP:(0): processing NONCE payload. message ID = 0
326618: Apr 25 16:58:51.833: ISAKMP:(0):found peer pre-shared key matching 44.33.11.74
326619: Apr 25 16:58:51.833: ISAKMP:(16314): processing vendor id payload
326620: Apr 25 16:58:51.833: ISAKMP:(16314): vendor ID is Unity
326621: Apr 25 16:58:51.833: ISAKMP:(16314): processing vendor id payload
326622: Apr 25 16:58:51.833: ISAKMP:(16314): vendor ID seems Unity/DPD but major 167 mismatch
326623: Apr 25 16:58:51.833: ISAKMP:(16314): vendor ID is XAUTH
326624: Apr 25 16:58:51.833: ISAKMP:(16314): processing vendor id payload
326625: Apr 25 16:58:51.833: ISAKMP:(16314): speaking to another IOS box!
326626: Apr 25 16:58:51.833: ISAKMP:(16314): processing vendor id payload
326627: Apr 25 16:58:51.833: ISAKMP:(16314):vendor ID seems Unity/DPD but hash mismatch
326628: Apr 25 16:58:51.833: ISAKMP:(16314):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
326629: Apr 25 16:58:51.833: ISAKMP:(16314):Old State = IKE_I_MM4 New State = IKE_I_MM4
326630: Apr 25 16:58:51.837: ISAKMP:(16314):Send initial contact
326631: Apr 25 16:58:51.837: ISAKMP:(16314):SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
326632: Apr 25 16:58:51.837: ISAKMP (16314): ID payload
next-payload : 8
type : 1
address : 10.20.255.106
protocol : 17
port : 500
length : 12
326633: Apr 25 16:58:51.837: ISAKMP:(16314):Total payload length: 12
326634: Apr 25 16:58:51.837: ISAKMP:(16314): sending packet to 44.33.11.74 my_port 500 peer_port 500 (I) MM_KEY_EXCH
326635: Apr 25 16:58:51.837: ISAKMP:(16314):Sending an IKE IPv4 Packet.
326636: Apr 25 16:58:51.837: ISAKMP:(16314):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
326637: Apr 25 16:58:51.837: ISAKMP:(16314):Old State = IKE_I_MM4 New State = IKE_I_MM5
326638: Apr 25 16:58:52.049: ISAKMP (16314): received packet from 44.33.11.74 dport 500 sport 500 Global (I) MM_KEY_EXCH
326639: Apr 25 16:58:52.049: ISAKMP:(16314): processing ID payload. message ID = 0
326640: Apr 25 16:58:52.049: ISAKMP (16314): ID payload
next-payload : 8
type : 2
FQDN name : ASA5510central.culmarex.local
protocol : 0
port : 0
length : 37
326641: Apr 25 16:58:52.049: ISAKMP:(0):: peer matches *none* of the profiles
326642: Apr 25 16:58:52.053: ISAKMP:(16314): processing HASH payload. message ID = 0
326643: Apr 25 16:58:52.053: ISAKMP:received payload type 17
326644: Apr 25 16:58:52.053: ISAKMP:(16314): processing keep alive: proposal=32767/32767 sec., actual=10/2 sec.
326645: Apr 25 16:58:52.053: ISAKMP:(16314): processing vendor id payload
326646: Apr 25 16:58:52.053: ISAKMP:(16314): vendor ID is DPD
326647: Apr 25 16:58:52.053: ISAKMP:(16314):SA authentication status:
authenticated
326648: Apr 25 16:58:52.053: ISAKMP:(16314):SA has been authenticated with 44.33.11.74
326649: Apr 25 16:58:52.053: ISAKMP:(16314):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
326650: Apr 25 16:58:52.053: ISAKMP:(16314):Old State = IKE_I_MM5 New State = IKE_I_MM6
326651: Apr 25 16:58:52.053: ISAKMP:(16314):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
326652: Apr 25 16:58:52.053: ISAKMP:(16314):Old State = IKE_I_MM6 New State = IKE_I_MM6
326653: Apr 25 16:58:52.053: ISAKMP:(16314):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
326654: Apr 25 16:58:52.053: ISAKMP:(16314):Old State = IKE_I_MM6 New State = IKE_P1_COMPLETE
326655: Apr 25 16:58:52.053: ISAKMP:(16314):IKE_DPD is enabled, initializing timers
326656: Apr 25 16:58:52.053: ISAKMP:(16314):beginning Quick Mode exchange, M-ID of -29212622
326657: Apr 25 16:58:52.053: ISAKMP:(16314):QM Initiator gets spi
326658: Apr 25 16:58:52.053: ISAKMP:(16314): sending packet to 44.33.11.74 my_port 500 peer_port 500 (I) QM_IDLE
326659: Apr 25 16:58:52.053: ISAKMP:(16314):Sending an IKE IPv4 Packet.
326660: Apr 25 16:58:52.057: ISAKMP:(16314):Node -29212622, Input = IKE_MESG_INTERNAL, IKE_INIT_QM
326661: Apr 25 16:58:52.057: ISAKMP:(16314):Old State = IKE_QM_READY New State = IKE_QM_I_QM1
326662: Apr 25 16:58:52.057: ISAKMP:(16314):Input = IKE_MESG_INTERNAL, IKE_PHASE1_COMPLETE
326663: Apr 25 16:58:52.057: ISAKMP:(16314):Old State = IKE_P1_COMPLETE New State = IKE_P1_COMPLETE
326664: Apr 25 16:58:52.169: ISAKMP:(15603):purging node 2088028010
326665: Apr 25 16:58:52.269: ISAKMP (16314): received packet from 44.33.11.74 dport 500 sport 500 Global (I) QM_IDLE
326666: Apr 25 16:58:52.269: ISAKMP: set new node -533571565 to QM_IDLE
326667: Apr 25 16:58:52.273: ISAKMP:(16314): processing HASH payload. message ID = -533571565
326668: Apr 25 16:58:52.273: ISAKMP:(16314): processing NOTIFY PROPOSAL_NOT_CHOSEN protocol 3
spi 0, message ID = -533571565, sa = B3492C4
326669: Apr 25 16:58:52.273: ISAKMP:(16314):deleting node -533571565 error FALSE reason "Informational (in) state 1"
326670: Apr 25 16:58:52.273: ISAKMP:(16314):Input = IKE_MESG_FROM_PEER, IKE_INFO_NOTIFY
326671: Apr 25 16:58:52.273: ISAKMP:(16314):Old State = IKE_P1_COMPLETE New State = IKE_P1_COMPLETE
326672: Apr 25 16:58:52.273: ISAKMP (16314): received packet from 44.33.11.74 dport 500 sport 500 Global (I) QM_IDLE
326673: Apr 25 16:58:52.273: ISAKMP: set new node -322332923 to QM_IDLE
326674: Apr 25 16:58:52.273: ISAKMP:(16314): processing HASH payload. message ID = -322332923
326675: Apr 25 16:58:52.273: ISAKMP:(16314): processing DELETE payload. message ID = -322332923
326676: Apr 25 16:58:52.273: ISAKMP:(16314):peer does not do paranoid keepalives.
326677: Apr 25 16:58:52.273: ISAKMP:(16314):deleting SA reason "No reason" state (I) QM_IDLE (peer 44.33.11.74)
326678: Apr 25 16:58:52.273: ISAKMP:(16314):deleting node -322332923 error FALSE reason "Informational (in) state 1"
326679: Apr 25 16:58:52.273: ISAKMP: set new node 476062227 to QM_IDLE
326680: Apr 25 16:58:52.273: ISAKMP:(16314): sending packet to 44.33.11.74 my_port 500 peer_port 500 (I) QM_IDLE
326681: Apr 25 16:58:52.273: ISAKMP:(16314):Sending an IKE IPv4 Packet.
326682: Apr 25 16:58:52.273: ISAKMP:(16314):purging node 476062227
326683: Apr 25 16:58:52.273: ISAKMP:(16314):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
326684: Apr 25 16:58:52.273: ISAKMP:(16314):Old State = IKE_P1_COMPLETE New State = IKE_DEST_SA
326685: Apr 25 16:58:52.273: ISAKMP:(16314):deleting SA reason "No reason" state (I) QM_IDLE (peer 44.33.11.74)
326686: Apr 25 16:58:52.273: ISAKMP:(0):Can't decrement IKE Call Admission Control stat outgoing_active since it's already 0.
326687: Apr 25 16:58:52.273: ISAKMP: Unlocking peer struct 0x1D75AB8 for isadb_mark_sa_deleted(), count 1
326688: Apr 25 16:58:52.277: ISAKMP:(16314):deleting node -29212622 error FALSE reason "IKE deleted"
326689: Apr 25 16:58:52.277: ISAKMP:(16314):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
326690: Apr 25 16:58:52.277: ISAKMP:(16314):Old State = IKE_DEST_SA New State = IKE_DEST_SA
