configure & troubleshoot anyconnect
5452
Beginner
ASA5516 9.8(2) site to site connection with Azure IKEv2 (no BGP) fails
I have a Azure subscription, with a virtual network where the gateway subnet is 172.26.0.0/27, and then I have a number of subnets, e.g. 172.26.1.0/24, 172.26.2.0/24, 172.26.3.0/24, ....
On the router side I have configured the network objects for 172.26.0.0/27 and 172.26.1.0/24.
The local network is 10.0.0.0/8.
This is the configuration I have used to setup the site to site connection on the router:
object network HQ-LAN
subnet 10.0.0.0 255.0.0.0
description The HQ LAN
object network AzureLabNet-LAN
subnet 172.26.1.0 255.255.255.0
description The Azure AzureLabNet LAN range
object network AzureLabNet-Gateway
subnet 172.26.0.0 255.255.255.224
object-group network AzureLabNet-network
description Azure AzureLabNet Virtual Network
network-object object AzureLabNet-LAN
network-object object AzureLabNet-Gateway
object-group network HQ-network
description HQ on-premises Network
network-object object HQ-LAN
access-list azure-vpn-acl extended permit ip object-group HQ-network object-group AzureLabNet-network log notifications
nat (LAN,INTERNET) source static HQ-network HQ-network destination static AzureLabNet-network AzureLabNet-network no-proxy-arp route-lookup
crypto ipsec ikev2 ipsec-proposal AZURE-TRANSFORM-2
protocol esp encryption aes-256
protocol esp integrity sha-256
crypto ipsec security-association lifetime seconds 3600
crypto ipsec security-association lifetime kilobytes 102400000
crypto ipsec security-association pmtu-aging infinite
crypto ipsec inner-routing-lookup
crypto map CRYPTO-MAP 1 match address azure-vpn-acl
crypto map CRYPTO-MAP 1 set peer 40.a.b.c
crypto map CRYPTO-MAP 1 set ikev2 ipsec-proposal AZURE-TRANSFORM-2
crypto map CRYPTO-MAP 1 set ikev2 pre-shared-key ********
crypto map CRYPTO-MAP 1 set security-association lifetime seconds 3600
crypto map CRYPTO-MAP 1 set nat-t-disable
crypto map CRYPTO-MAP interface INTERNET
crypto ca trustpool policy
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 2
prf sha
lifetime seconds 28800
crypto ikev2 enable INTERNET
group-policy AzureGroupPolicy internal
group-policy AzureGroupPolicy attributes
vpn-tunnel-protocol ikev2
dynamic-access-policy-record DfltAccessPolicy
tunnel-group 40.a.b.c type ipsec-l2l
tunnel-group 40.a.b.c general-attributes
default-group-policy AzureGroupPolicy
tunnel-group 40.a.b.c ipsec-attributes
ikev2 remote-authentication pre-shared-key ********
ikev2 local-authentication pre-shared-key ********
no tunnel-group-map enable peer-ip
tunnel-group-map default-group 40.a.b.c
sysopt connection tcpmss 1350
sysopt connection preserve-vpn-flows
The connection seems to reach the point where a IKEv2 tunnel is setup, but then the tunnel get rejected with the following error:
3 Sep 10 2018 14:39:38 751022         Local:80.x.y.w:500 Remote:40.a.b.c:500 Username:40.a.b.c IKEv2 Tunnel rejected: Crypto Map Policy not found for remote traffic selector 0.0.0.0/255.255.255.255/0/65535/0 local traffic selector 0.0.0.0/255.255.255.255/0/65535/0!
In debug, I found:
IKEv2-PROTO-2: (404): Processing IKE_AUTH message
IKEv2-PLAT-2: (404): Crypto Map: No proxy match on map CRYPTO-MAP seq 1
IKEv2-PROTO-1: (404): Failed to find a matching policy
IKEv2-PROTO-1: (404): Received Policies:
ESP: Proposal 1: AES-GCM-256 Don't use ESN
ESP: Proposal 2: AES-CBC-256 SHA96 Don't use ESN
ESP: Proposal 3: 3DES SHA96 Don't use ESN
ESP: Proposal 4: AES-CBC-256 SHA256 Don't use ESN
ESP: Proposal 5: AES-CBC-128 SHA96 Don't use ESN
ESP: Proposal 6: 3DES SHA256 Don't use ESN
IKEv2-PROTO-1: (404): Expected Policies:
IKEv2-PROTO-5: (404): Failed to verify the proposed policies
and also:
IKEv2-PROTO-5: (237): SM Trace-> SA: I_SPI=8D624530AA96162A R_SPI=4A613765BD92DF8F (I) MsgID = 00000004 CurState: DELETE Event: EV_FREE_SA
IKEv2-PROTO-2: (237): Deleting SA
IKEv2-PROTO-1: session is not there in tree
IKEv2-PLAT-2:
CONNECTION STATUS: DOWN... peer: 40.a.b.c:500, phase1_id: 40.a.b.c
IKEv2-PLAT-2: (237): IKEv2 session deregistered from session manager. Reason: 6
IKEv2-PLAT-2: (237): session manager killed ikev2 tunnel. Reason: IKE Delete
IKEv2-PLAT-2: (237): PSH cleanup
IKEv2-PLAT-5: Active ike sa request deleted
IKEv2-PLAT-5: Decrement count for incoming active
IKEv2-PLAT-2: (404): Encrypt success status returned via ipc 1
IKEv2-PLAT-1: Failed to remove peer correlation entry from cikePeerCorrTable. Local Type = 0. Local Address = 0.0.0.0. Remote Type = 0. Remote Address = 0.0.0.0. Correlation Peer Index = 0. IPSEC Tunnel Index = 0.
IKEv2-PLAT-2: Received PFKEY delete SA for SPI 0xAA15ED6E error FALSE
IKEv2-PLAT-2: Received PFKEY delete SA for SPI 0xFBC930C6 error FALSE
IKEv2-PLAT-2: Received PFKEY delete SA for SPI 0xDA2A46C2 error FALSE
IKEv2-PLAT-2: Received PFKEY delete SA for SPI 0x2EDA754D error FALSE
Any suggestion on how to fix this?
Everyone's tags (4)
1 ACCEPTED SOLUTION
Beginner
Re: ASA5516 9.8(2) site to site connection with Azure IKEv2 (no BGP) fails
I found a solution:
gateway# show crypto isa
There are no IKEv1 SAs
IKEv2 SAs:
Session-id:*****, Status:UP-ACTIVE, IKE count:1, CHILD count:1
Tunnel-id Local                                               Remote                                                  Status         Role
********** 80.x.w.y/500                                   40.a.b.c/500                                         READY    INITIATOR
      Encr: AES-CBC, keysize: 256, Hash: SHA256, DH Grp:2, Auth sign: PSK, Auth verify: PSK
      Life/Active Time: 28800/3135 sec
Child sa: local selector  10.0.0.0/0 - 10.255.255.255/65535
          remote selector 172.26.1.0/0 - 172.26.1.255/65535
          ESP spi in/out: 0x********/0x********
Reading the list of Microsoft validated VPN devices and device configuration guides in the "About VPN devices and IPsec/IKE parameters for Site-to-Site VPN Gateway connections" page, on the Cisco ASA row, next to IKEv2 I noticed an asterisk, and down below the list I read
Cisco ASA versions 8.4+ add IKEv2 support, can connect to Azure VPN gateway using custom IPsec/IKE policy with "UsePolicyBasedTrafficSelectors" option. Refer to this how-to article.
I understand from this that I had to set the UsePolicyBasedTrafficSelectors property and therefore create a custom IKE/IPSEC policy, which I did on the Azure Cloud shell with the following code:
$RG          = "MyRG"
$ConnectionName = "STS-Azure-HQ"
$connection  = Get-AzureRmVirtualNetworkGatewayConnection -Name $ConnectionName -ResourceGroupName $RG
$ipsecpolicy = New-AzureRmIpsecPolicy -IkeEncryption AES256 -IkeIntegrity SHA256 -DhGroup DHGroup2 -IpsecEncryption AES256 -IpsecIntegrity SHA256 -PfsGroup PFS2 -SALifeTimeSeconds 3600 -SADataSizeKilobytes 2048
Set-AzureRmVirtualNetworkGatewayConnection -VirtualNetworkGatewayConnection $connection -UsePolicyBasedTrafficSelectors $True -IpsecPolicies $ipsecpolicy
I then reconfigured the ASA router to match the IKE/IPSEC policy:
configure terminal
 exit
 encryption aes-256
 integrity sha256
 group 2
 prf sha256 sha
 exit
The prf sha256 sha was the last bit I changed, I reckon it may work also just with sha256, but I haven't tried it.
Before that I also added all the 12 Azure subnets in my ASA traffic selector, which probably helped as well.
 subnet 172.26.0.0 255.255.224.0
 description The Azure Gateway range
 exit
object network AzureLabNet-LAN-1
 description The Azure AzureLabNet LAN #1 range
 exit
object network AzureLabNet-LAN-2
 subnet 172.26.2.0 255.255.255.0
 description The Azure AzureLabNet LAN #2 range
 exit
object network AzureLabNet-LAN-3
 subnet 172.26.3.0 255.255.255.0
 description The Azure AzureLabNet LAN #3 range
 exit
object network AzureLabNet-LAN-4
 subnet 172.26.4.0 255.255.255.0
 description The Azure AzureLabNet LAN #4 range
 exit
object network AzureLabNet-LAN-5
 subnet 172.26.5.0 255.255.255.0
 description The Azure AzureLabNet LAN #5 range
 exit
object network AzureLabNet-LAN-6
 subnet 172.26.6.0 255.255.255.0
 description The Azure AzureLabNet LAN #6 range
 exit
object network AzureLabNet-LAN-7
 subnet 172.26.7.0 255.255.255.0
 description The Azure AzureLabNet LAN #7 range
 exit
object network AzureLabNet-LAN-8
 subnet 172.26.8.0 255.255.255.0
 description The Azure AzureLabNet LAN #8 range
 exit
object network AzureLabNet-LAN-9
 subnet 172.26.9.0 255.255.255.0
 description The Azure AzureLabNet LAN #9 range
 exit
object network AzureLabNet-LAN-10
 subnet 172.26.10.0 255.255.255.0
 description The Azure AzureLabNet LAN #10 range
 exit
object network AzureLabNet-LAN-11
 subnet 172.26.11.0 255.255.255.0
 description The Azure AzureLabNet LAN #11 range
 exit
 network-object object AzureLabNet-LAN-1
 network-object object AzureLabNet-LAN-2
 network-object object AzureLabNet-LAN-3
 network-object object AzureLabNet-LAN-4
 network-object object AzureLabNet-LAN-5
 network-object object AzureLabNet-LAN-6
 network-object object AzureLabNet-LAN-7
 network-object object AzureLabNet-LAN-8
 network-object object AzureLabNet-LAN-9
 network-object object AzureLabNet-LAN-10
 network-object object AzureLabNet-LAN-11
exit
5 REPLIES 5
Beginner
Update about the Azure side:
The address space on the virtual network is 172.26.0.0/16, the gateway subnet is 172.26.0.0/27, and the subnets are 172.26.1.0/24, 172.26.2.0/24, 172.26.3.0/24, 172.26.4.0/24, 172.26.5.0/24, 172.26.6.0/24, 172.26.7.0/24, 172.26.8.0/24, 172.26.9.0/24, 172.26.10.0/24, 172.26.11.0/24.
At the moment I have only one VM up on 172.26.1.0/24 which I am using to test the VPN (and another whole lot of VMs spread across the other subnets).
Collaborator
I think Azure used GCM 256. Try GCM 256 for your phase 2
https://docs.microsoft.com/en-us/azure/azure-stack/azure-stack-vpn-gateway-settings#ipsecike-parameters
John
**Please rate posts you find helpful**
Beginner
Dear John, thanks, I did try that, but it didn't work. That was actually for Azure Stack, not for Azure, useful stuff to know :)
Beginner
I found a solution:
IKEv2 SAs:
$RG          = "MyRG"
configure terminal
 exit
 encryption aes-256
 integrity sha256
 group 2
 prf sha256 sha
 exit
 exit
 exit
 exit
 exit
 exit
 exit
 exit
 exit
 exit
 exit
 exit
 exit
exit
Highlighted
Beginner
Thanks for following up and posting the solution you found, it was the answer to our matching issue!
