ASDM 7.0(2) not showing bookmark information for Remote Access VPN
ngkuchman
I have an ASA 5550 running 8.4(5) and have installed ASDM 7.0(2), but when I try to manage the bookmarks under the Remote Access - Portal when I try to edit an individual item in a bookmark list the screen does not display any information. Is this a know bug, or do I need to have a specific java version for the new ASDM? As a side note, I have not noticed any other issues with the new version of ASDM, only the bookmarks. I initially tried to downgrade the ASDM version that I was using to connect, but it will no longer allow me to connect.
6 Replies 6
Are you using Java 7?
Does it happen on a different system?
Please attach a screenshot.
Portu.
Please rate any helpful posts
I just tried from another computer with the same result. Both are using ASDM 7.0(2) and Java 7 update 9
Not sure if it makes a difference, both computers are also Windows 7 x64.
Thanks for the attachment.
Please try from a different computer running an previous Java version (1.6 for instance) and let me know.
On the other hand, have you install the latest Microsoft Security updates?
HTH.
ju_mobile
I've seen similar on 8.4(3) when looking at Anyconnect profiles the radial options show as unticked. However, they most definitely are, I'd recommend familiarising yourself with the console...
Ju
I can't seem to find any documentation that shows how to update/configure advanced bookmark post information via the CLI. Can someone point me in the right direction, or is it only possible via ASDM?
Hi there
I am sorry for any delay.
Please check this out:
ASDM 7.0 Edit Bookmark Window empty.
Symptom:
In the Edit Bookmark Window all fields are empty.
Conditions:
ASDM 7.0
Workaround:
If running any ASA code before 9.0 downgrade to ASDM 6.4.
If running ASA 9.0, there is no workaround.
Fixed-In
7.1(1.2)
You may try with the latest version available Release 7.1.1
HTH.
