Beginner
ASR IPSEC client to site NAT issues
Hi All,
I recently am trying to fix/trouble shoot a VPN client to site I configured on an ASR 1001. I had the configuration working then it stopped...Also the VPN works when its not going through NAT. However once I try connecting through NAT, I'm not even prompted for login, phase one of the session fails. Overall its a fairly simple configuration, although I've had issues with doing Port overload NAT since you cannot map NAT to the outside interface without DHCP failing...(I don't know if the mappings are related to this issue)
I've provided my current configurations and debugging logs. Please see attachments.
Matt
Everyone's tags (3)
