43275
Highlighted
Beginner
Asymmetric NAT rules matched for forward and reverse flows
Hi! I don't know why this comes up in the logs when I have configured my vpn like so:
crypto dynamic-map L2L_MAP 50 set reverse-route
crypto dynamic-map OUTSIDE_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map OUTSIDE_dyn_map 40 set pfs
crypto dynamic-map OUTSIDE_dyn_map 40 set transform-set ESP-3DES-SHA
crypto dynamic-map OUTSIDE_dyn_map 60 set pfs
crypto dynamic-map OUTSIDE_dyn_map 60 set transform-set ESP-3DES-SHA
crypto dynamic-map OUTSIDE_dyn_map 65535 set transform-set ESP-3DES-SHA
crypto dynamic-map OUTSIDE_dyn_map 65535 set security-association lifetime seconds 288000
crypto dynamic-map OUTSIDE_dyn_map 65535 set security-association lifetime kilobytes 4608000
crypto dynamic-map INSIDE_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map L2L_MAP 20 match address IDP_VPN
crypto map L2L_MAP 20 set peer x.x.x.x
crypto map L2L_MAP 20 set transform-set ESP-3DES-SHA
crypto map L2L_MAP 40 match address cp_l2l_map_40
crypto map L2L_MAP 40 set peer x.x.x.x
crypto map L2L_MAP 40 set transform-set ESP-3DES-SHA
crypto map L2L_MAP 60 match address bwi_l2l
crypto map L2L_MAP 60 set peer x.x.x.x
crypto map L2L_MAP 60 set transform-set ESP-3DES-SHA
crypto map L2L_MAP 80 match address outside_80_cryptomap
crypto map L2L_MAP 80 set peer x.x.x.x
crypto map L2L_MAP 80 set transform-set ESP-3DES-SHA
crypto map L2L_MAP 65535 ipsec-isakmp dynamic OUTSIDE_dyn_map
crypto map L2L_MAP interface outside
crypto map INSIDE_map 65535 ipsec-isakmp dynamic INSIDE_dyn_map
crypto map INSIDE_map interface inside
I am able to connect successfully via vpn client.  Its just that i cant reach the internal servers...  Any ideas?
i get this error:
Oct 18 2012 00:52:37: %ASA-5-305013: Asymmetric NAT rules matched for forward and reverse flows; Connection for udp src outside:10.10.13.221/137 dst inside:10.10.13.255/137 denied
30 REPLIES 30
What is your VPN pool subnet? Pls configure a unique subnet which is not the same subnet as your inside network.
Also have you configure NAT exemption for those traffic?
Beginner
I now changed it to
ip local pool inshse-vpn-pool2 192.168.6.220-192.168.6.230 mask 255.255.255.0
but i get same looking errors
Oct 18 2012 01:16:20: %ASA-5-305013: Asymmetric NAT rules matched for forward and reverse flows; Connection for udp src outside:192.168.6.220/51119 dst inside:10.10.10.52/53 denied due to NAT reverse path failure
Have you configured NAT exemption for traffic between 10.10.13.0 and 192.168.6.0?
which version of ASA are you running?
Beginner
The version is 8.2.
I added:
nat (inside) 0 access-list nonatacl
access-list nonatacl extended permit ip 192.168.6.0 255.255.255.0 any
I still get the same error:
Oct 18 2012 01:37:34: %ASA-5-305013: Asymmetric NAT rules matched for forward and reverse flows; Connection for udp src outside:192.168.6.220/64932 dst inside:10.10.10.52/53 denied due to NAT reverse path failure
192.168.6.0/24 should be the destination, not the source.
access-list nonatacl permit ip 10.10.13.0 255.255.255.0 192.168.6.0 255.255.255.0
Then "clear xlate", it should work after that.
Beginner
I have added:
access-list nonatacl extended permit ip 10.10.13.0 255.255.255.0 192.168.6.0 255.255.255.0
I still get the same error. i get no hits in the acl.
access-list nonatacl line 8 extended permit ip 10.10.13.0 255.255.255.0 192.168.6.0 255.255.255.0 (hitcnt=0) 0x6ba60382
10.10.13.0 ---> is the inside network
can u pls share the full config, thx
Beginner
Re: Asymmetric NAT rules matched for forward and reverse flows
I put in the important configs:
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.0 standby x.x.x.x
ospf cost 10
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.10.13.5 255.255.255.0 standby 10.10.13.6
ospf cost 10
interface GigabitEthernet0/2
nameif dmz
security-level 50
no ip address
ospf cost 10
interface GigabitEthernet0/2.720
vlan 720
nameif dmz-vsp
security-level 50
ip address 172.24.0.1 255.255.255.0 standby 172.24.0.2
ospf cost 10
interface GigabitEthernet0/2.724
vlan 724
nameif dmz-dbz
security-level 75
ip address 172.24.4.1 255.255.255.0 standby 172.24.4.2
ospf cost 10
interface GigabitEthernet0/2.725
vlan 725
nameif dmz-smtp
security-level 50
ip address 172.24.5.1 255.255.255.0 standby 172.24.5.2
ospf cost 10
dns domain-lookup outside
dns domain-lookup inside
dns server-group DefaultDNS
name-server 10.10.10.50
domain-name xxxx.local
access-list nonatacl extended permit ip 10.10.0.0 255.255.0.0 10.40.4.0 255.255.255.0
access-list nonatacl extended permit ip 172.16.0.0 255.255.0.0 10.40.4.0 255.255.255.0
access-list nonatacl extended permit ip 192.168.2.0 255.255.255.0 10.40.4.0 255.255.255.0
access-list nonatacl extended permit ip 192.168.3.0 255.255.255.0 10.40.4.0 255.255.255.0
access-list nonatacl extended permit ip 10.10.0.0 255.255.0.0 10.40.14.0 255.255.255.0
access-list nonatacl extended permit ip 10.10.13.0 255.255.255.0 10.10.10.0 255.255.255.0
access-list nonatacl extended permit ip 10.10.10.0 255.255.255.0 10.10.13.0 255.255.255.0
access-list nonatacl extended permit ip 192.168.6.0 255.255.255.0 10.10.13.0 255.255.255.0
global (outside) 201 192.168.16.1-192.168.16.250
global (outside) 202 10.201.5.145-10.201.5.158
global (outside) 4 10.10.13.180-10.10.13.189 netmask 255.0.0.0
global (outside) 101 interface
global (outside) 1 x.x.x.x netmask 255.0.0.0
global (inside) 204 10.10.13.70-10.10.13.79 netmask 255.0.0.0
nat (inside) 201 access-list NAT_TO_IDP
nat (inside) 202 access-list inside2-vsp_nat_outbound
nat (inside) 101 0.0.0.0 0.0.0.0
nat (dmz-vsp) 202 access-list dmz-vsp_nat_outbound
nat (dmz-vsp) 101 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
route inside 10.0.0.0 255.240.0.0 10.10.13.1 1
route inside 10.40.1.0 255.255.255.0 10.10.13.1 1
route inside 10.40.2.0 255.255.255.0 10.10.13.1 1
route inside 10.40.3.0 255.255.255.0 10.10.13.1 1
route inside 10.40.4.0 255.255.255.0 10.10.13.1 1
route inside 10.40.13.0 255.255.255.0 10.10.13.1 1
route inside 10.40.254.0 255.255.255.0 10.10.13.1 1
route inside 172.16.0.0 255.255.0.0 10.10.13.1 1
route inside 192.168.2.0 255.255.255.0 10.10.13.1 1
dynamic-access-policy-record DfltAccessPolicy
aaa-server VPN_Auth protocol radius
aaa-server VPN_Auth (inside) host 10.10.2.20
timeout 5
key *****
no mschapv2-capable
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map L2L_MAP 60 match address nonatacl
crypto isakmp enable outside
crypto isakmp enable inside
crypto isakmp enable dmz
crypto isakmp enable dmz-vsp
crypto isakmp policy 20
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
group-policy ihasavpn2_gp internal
group-policy ihasavpn2_gp attributes
dns-server value 10.10.10.52
vpn-tunnel-protocol IPSec
default-domain value xxxx.local
tunnel-group ihasavpn2 type remote-access
tunnel-group ihasavpn2 general-attributes
address-pool inshse-vpn-pool2
authentication-server-group VPN_Auth
authentication-server-group (inside) VPN_Auth
default-group-policy ihasavpn2_gp
tunnel-group ihasavpn2 ipsec-attributes
pre-shared-key *****
tunnel-group ihasavpn2 ppp-attributes
authentication ms-chap-v2
Pls remove the following:
Also share the output of: show route | i 192.168.
Beginner
i removed the that acl line.
S    192.168.2.0 255.255.255.0 [1/0] via 10.10.13.1, inside
where do you connect from? inside or outside?
Beginner
i connect from the outside (public internet) using vpn client.
Can you pls share the output of:
show cry ipsec sa
Beginner
output:
There are no ipsec sas
