Best way for users to install AnyConnect
billmatthews
We use WebVPN, with AnyConnect available as a web based installation.
For users that prefer to permenantly install AnyConnect, what's the best way for them to do that?
If the web launch fails, they're given the option to download the client.  But if the web launch succeeds, then the download link is grayed out.
Is there a URL or method they can download/install AnyConnect?
Bill
jean.rozycki
Hello Bill,
I think there are different ways to do that.
- You can tell ASA to leave AC installed on the PCs (svc keep-installer ...)
- You can add some Web link ("Web applications") where users can download the AC client installation files and give the user the option to select these pages before AC starts (svc ask ...)
Hope this helps,
