07-11-2011 07:12 AM
I am replacing an cisco 1601 ISDN router (wich is working) with a cisco 1841 (with a Wic-1B-S/T-v3 ISDN card installed
the config (including userid & password) have been copied over
When tested the ISDN link attempts to come up then fails with a cause code of 16
the following is a debug of the ISDN
The config of the router is
F1EBMWISDN-01#show run
Building configuration...
Current configuration : 4518 bytes
version 15.0
service password-encryption
hostname F1EBMWISDN-01
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$I3Sw$rmt0vWQ.JPE8aEWQGLMyz.
enable password 7 09601A3B1608121D
aaa new-model
aaa group server tacacs+ UNI
server 160.3.16.81
aaa authentication login default group UNI local
aaa authentication enable default group UNI enable
aaa accounting exec default
action-type start-stop
group UNI
aaa accounting commands 15 default
action-type stop-only
group UNI
aaa session-id common
no ip source-route
ip cef
isdn switch-type basic-net3
license udi pid CISCO1841 sn FCZ1519C3XT
username nw-admin password 7 113E18091201595C557A
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 192.168.244.4 255.255.255.0
no ip redirects
ip nat inside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
no cdp enable
standby 253 ip 192.168.244.6
standby 253 timers 5 15
standby 253 priority 201
standby 253 preempt
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI0/0/0
description Connects to
no IP address
encapsulation ppp
no ip route-cache
dialer pool-member 1
isdn point-to-point-setup
ppp multilink
no cdp enable
interface Dialer1
ip address negotiated
ip nat outside
no ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer remote-name ASACC1
dialer string 00498935474900
dialer load-threshold 3 outbound
dialer-group 1
ppp authentication chap
ppp chap hostname spabuees
ppp chap password 7 072A297B7C004A3344
ppp multilink
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static 10.201.80.204 160.48.223.41
ip route 0.0.0.0 0.0.0.0 192.168.244.1
ip route 160.48.223.41 255.255.255.255 Dialer1
ip route 160.50.6.48 255.255.255.255 Dialer1
ip route 172.25.195.107 255.255.255.255 Dialer1
ip tacacs source-interface FastEthernet0/0
access-list 100 permit ip host 160.48.223.41 any
access-list 100 permit ip host 10.201.80.204 any
dialer-list 1 protocol ip permit
tacacs-server host 160.3.16.81
tacacs-server directed-request
control-plane
line con 0
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
transport input telnet
line vty 5 15
access-class 23 in
privilege level 15
scheduler allocate 20000 1000
end
F1EBMWISDN-01#
*Jul 11 13:34:47.731: ISDN BR0/0/0 EVENT: UserIdle: callid 0x8003 received ISDN_CALL (0x0)
*Jul 11 13:34:47.731: ISDN BR0/0/0 EVENTd: UserIdle: Call to 00498935474900 at 64 Kb/s
*Jul 11 13:34:47.731: ISDN BR0/0/0 EVENTd: isdn_get_guid: Cannot allocate a GUID (5)
*Jul 11 13:34:47.731: ISDN BR0/0/0 EVENT: process_bri_call: call id 0x8003, called_number 00498935474900, Guid 00740000FFFF speed 64, call type DATA, bchan -1 clng_e
*Jul 11 13:34:47.731: ISDN BR0/0/0 EVENTd: process_bri_call: No name in GTD
*Jul 11 13:34:47.731: ISDN BR0/0/0 EVENTd: calltrkr_setup_received: isdn_info=1675789144l, call_id=0x8003 ORIGINATE
*Jul 11 13:34:47.731: ISDN BR0/0/0 EVENTd: calltrkr_setup_received: calltracker disabled
*Jul 11 13:34:47.731: ISDN BR0/0/0 Q931: Sending SETUP callref = 0x0003 callID = 0x8003 switch = basic-net3 interface = User
*Jul 11 13:34:47.731: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8 callref = 0x03
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Called Party Number i = 0x80, '00498935474900'
Plan:Unknown, Type:Unknown
*Jul 11 13:34:47.935: ISDN BR0/0/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x83
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8288 - In-band info or appropriate now available
*Jul 11 13:34:47.935: ISDN BR0/0/0 EVENT: process_rxstate: ces/callid 1/0x8003 calltype 1 HOST_INFORMATION
*Jul 11 13:34:47.935: ISDN BR0/0/0 EVENTd: host_information: call id 0x8003 b channel 0 assigned by switch
*Jul 11 13:34:54.027: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x83
*Jul 11 13:34:54.027: ISDN BR0/0/0 EVENT: process_rxstate: ces/callid 1/0x8003 calltype 1 HOST_PROCEEDING
*Jul 11 13:34:54.027: ISDN BR0/0/0 EVENTd: host_more_info: B-channel assigned in previous message call id 0x8003
*Jul 11 13:34:54.059: ISDN BR0/0/0 Q931: RX <- CONNECT pd = 8 callref = 0x83
*Jul 11 13:34:54.059: ISDN BR0/0/0 EVENT: process_rxstate: ces/callid 1/0x8003 calltype 1 HOST_CONNECT
*Jul 11 13:34:54.059: ISDN BR0/0/0 EVENTd: isdn_report: callid 0x8003
*Jul 11 13:34:54.059: %LINK-3-UPDOWN: Interface BRI0/0/0:1, changed state to up
*Jul 11 13:34:54.063: %DIALER-6-BIND: Interface BR0/0/0:1 bound to profile Di1
*Jul 11 13:34:54.063: %ISDN-6-CONNECT: Interface BRI0/0/0:1 is now connected to 00498935474900 N/A
*Jul 11 13:34:54.063: ISDN BR0/0/0 EVENTd: isdn_mib_update: Update Charge Units 0 hndl=0
*Jul 11 13:34:54.063: ISDN BR0/0/0 EVENTd: calltrkr_call_connect: isdn_info=0x63E2AB44, call_id=0x8003
*Jul 11 13:34:54.063: ISDN BR0/0/0 EVENTd: calltrkr_call_connect: hndl=0l, cntrl_slot=0, cntrl_port=0, cntrl_channel=0.
*Jul 11 13:34:54.063: ISDN BR0/0/0 EVENTd: host_connect: Connected to 00498935474900 on B1 at 64 Kb/s
*Jul 11 13:34:54.067: ISDN BR0/0/0 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x03
*Jul 11 13:34:55.311: ISDN BR0/0/0 EVENT: UserIdle: callid 0x8003 received ISDN_HANGUP (0x1)
*Jul 11 13:34:55.315: ISDN BR0/0/0 EVENT: isdn_hangup: Hangup call to call id 0x8003 ces = 1
*Jul 11 13:34:55.315: ISDN BR0/0/0 EVENTd: process_disconnect: call id 0x8003, call type is DATA, b_idb 0x63E29788, ces 1, cause Normal call clearing(0x10)
*Jul 11 13:34:55.315: %ISDN-6-DISCONNECT: Interface BRI0/0/0:1 disconnected from 00498935474900 asacc1, call lasted 1 seconds
*Jul 11 13:34:55.315: ISDN BR0/0/0 EVENTd: isdn_mib_update: Update Charge Units 0 hndl=0
*Jul 11 13:34:55.315: ISDN BR0/0/0 EVENTd: calltrkr_call_disconnected: isdn_info=0x63E2AB44, call_id=0x8003
*Jul 11 13:34:55.315: ISDN BR0/0/0 EVENTd: calltrkr_call_disconnected: hndl=0l, cause=16, Normal call clearing
*Jul 11 13:34:55.315: ISDN BR0/0/0 EVENTd: process_disconnect: Raw Release Message
*Jul 11 13:34:55.315: 0500018003040802FF9008028090
*Jul 11 13:34:55.315: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x03
Cause i = 0x8090 - Normal call clearing
*Jul 11 13:34:55.495: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x83
*Jul 11 13:34:55.495: ISDN EVENTd: cc_clear_free_list freeing 0x63E8CA80
*Jul 11 13:34:55.495: ISDN BR0/0/0 EVENT: process_rxstate: ces/callid 1/0x8003 calltype 1 HOST_DISCONNECT_ACK
*Jul 11 13:34:55.495: ISDN BR0/0/0 EVENTd: calltrkr_call_cleared: isdn_info=0x63E28358, call_id=0x8003
*Jul 11 13:34:55.495: ISDN BR0/0/0 EVENTd: calltrkr_call_cleared: isdn_info=0x63E2AB44, call_id=0x8003
*Jul 11 13:34:55.495: ISDN BR0/0/0 EVENTd: calltrkr_call_cleared: hndl=0, cause=16, Normal call clearing
*Jul 11 13:34:55.495: ISDN BR0/0/0 EVENTd: host_disconnect_ack: call type is DATA
*Jul 11 13:34:55.495: %LINK-3-UPDOWN: Interface BRI0/0/0:1, changed state to down
*Jul 11 13:34:55.499: %DIALER-6-UNBIND: Interface BR0/0/0:1 unbound from profile Di1
*Jul 11 13:34:55.499: ISDN BR0/0/0 EVENTd: isdn_report: callid 0x8003
*Jul 11 13:34:55.499: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x03
*Jul 11 13:34:57.359: ISDN BR0/0/0 EVENT: UserIdle: callid 0x8004 received ISDN_CALL (0x0)
*Jul 11 13:34:57.359: ISDN BR0/0/0 EVENTd: UserIdle: Call to 00498935474900 at 64 Kb/s
*Jul 11 13:34:57.359: ISDN BR0/0/0 EVENTd: isdn_get_guid: Cannot allocate a GUID (5)
*Jul 11 13:34:57.359: ISDN BR0/0/0 EVENT: process_bri_call: call id 0x8004, called_number 00498935474900, Guid 00740000FFFF speed 64, call type DATA, bchan -1 clng_e
*Jul 11 13:34:57.359: ISDN BR0/0/0 EVENTd: process_bri_call: No name in GTD
*Jul 11 13:34:57.363: ISDN BR0/0/0 EVENTd: calltrkr_setup_received: isdn_info=1675789144l, call_id=0x8004 ORIGINATE
*Jul 11 13:34:57.363: ISDN BR0/0/0 EVENTd: calltrkr_setup_received: calltracker disabled
*Jul 11 13:34:57.363: ISDN BR0/0/0 Q931: Sending SETUP callref = 0x0004 callID = 0x8004 switch = basic-net3 interface = User
*Jul 11 13:34:57.363: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8 callref = 0x04
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
*Jul 11 13:34:57.535: ISDN BR0/0/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0x84
Channel ID i = 0x89
Exclusive, B1
*Jul 11 13:34:57.535: ISDN BR0/0/0 EVENT: process_rxstate: ces/callid 1/0x8004 calltype 1 HOST_INFORMATION
*Jul 11 13:34:57.535: ISDN BR0/0/0 EVENTd: host_information: call id 0x8004 b channel 0 assigned by switch
Solved! Go to Solution.
07-12-2011 10:09 AM
07-12-2011 10:09 AM
Take debug ppp neg, debug ppp auth.
Do not take any other debug.
07-13-2011 12:28 AM
Identified that the difference in the IOS dictated that the "Callin" parameter was required on the PPP Chap authentication statement on the Dialer 1 interface, this prevents the remote router trying to authenticate (which wa s the reason the failure was occuring
Glyn
07-14-2011 03:59 PM
Thanks for the nice rating and good luck!
