Bridging traffic between two devices connected to VPN
Craddockc
Level 3
Level 3
Community,
I have two devices on the Anyconnect VPN. However, these devices on the VPN are not able to communicate with each other. Is it possible to bridge the traffic in the firewall between two devices connected via VPN? or is this kind of behavior blocked by default in the firewall? Both devices are in the same subnet once they connect to the VPN.
Thanks.
Yes it's possible, but it depends on your configuration, which is something you would need to share to give you a bit of help.
Philip,
What do you need to know? Im happy to post anything that will help. Thanks.
