12-29-2010 04:24 AM
I have a cisco router 2821 with IOS c2800nm-ipvoice_ivs-mz.124-24.T3.bin.
The question is that I´m trying to configure a L2TP tunnel but the router don´t accept that I configure the interface Virtual-PPP1:
(config)#interface ?
Async Async interface
Auto-Template Auto-Template interface
BRI ISDN Basic Rate Interface
BVI Bridge-Group Virtual Interface
CDMA-Ix CDMA Ix interface
CTunnel CTunnel interface
Cellular Cellular WAN interface
Dialer Dialer interface
GigabitEthernet GigabitEthernet IEEE 802.3z
Group-Async Async Group interface
Lex Lex interface
Loopback Loopback interface
MFR Multilink Frame Relay bundle interface
Multilink Multilink-group interface
Null Null interface
Port-channel Ethernet Channel of interfaces
SSLVPN-VIF SSLVPN Virtual Interface
Serial Serial
Tunnel Tunnel interface
Vif PGM Multicast Host interface
Virtual-PPP Virtual PPP interface
Virtual-Template Virtual Template interface
Virtual-TokenRing Virtual TokenRing
range interface range command
vmi Virtual Multipoint Interface
(config)#interface vitual-PPP1
% Invalid input detected at '^' marker.
The pseudoeire is not even recognized:
(config)#pse?
% Unrecognized command
I already configure:
vpdn enable
ip cef
l2tp-class L2TP
authentication
In cisco site this IOS support L2TP. The router accept the command show l2tp
Best Regards,
Nelson Mendes
Solved! Go to Solution.
01-06-2011 06:22 PM
I would recommend c2800nm-adventerprisek9_ivs-mz.124-24.T3. It's a superset of the -ipvoice_ivs- feature set that you have now, so you should not lose any IOS functionalities, see:
http://www.cisco.com/en/US/partner/prod/collateral/routers/ps5854/prod_bulletin0900aecd802a9493.html
Wen
12-29-2010 05:05 AM
Following is the configuration guide to configure L2TP on a cisco router
http://www.cisco.com/en/US/tech/tk801/tk703/technologies_configuration_example09186a00800946f5.shtml
Regarding (config)#interface vitual-PPP1
There is a typo at virtual .
It should be like interface virtual-ppp 1
Hope this helps!!
Manasi
12-29-2010 08:08 AM
Sorry,
this is the correct copy/paste:
(config)#interface virtual-PPP 1
12-29-2010 05:29 PM
what code are you running on the router?
Can you paste the output of sh ver ?
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_i1.html#wp1011879
The command was introduced in 12.3(2) T
Manasi
12-29-2010 09:57 PM
Hi, Nelson:
The interface virtual-ppp and pseudoeire configuration requires the l2tpv3 pseudoeire-class feature, which is only available in the -entservicesk9-, -spservicesk9-, -advipservicesk9-, or -adventerprisek9- IOS feature sets. That's why you can't configure this in the -ipvoice_ivs- feature set as you have. You may want to upgrade the feature set and see if that helps.
Wen
01-06-2011 07:02 AM
This particular router is also a IP2IP gateway.
My afraid is that when I change the IOS some actual configuration is not recognized and the customer get the voip down (very critical).
The show version of the router is:
Cisco IOS Software, 2800 Software (C2800NM-IPVOICE_IVS-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 23-Mar-10 06:43 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
CSTorresDistr uptime is 14 weeks, 6 days, 13 hours, 52 minutes
System returned to ROM by Reload Command at 02:00:00 PORT Fri Sep 24 2010
System restarted at 02:01:26 PORT Fri Sep 24 2010
System image file is "flash:c2800nm-ipvoice_ivs-mz.124-24.T3.bin"
Cisco 2821 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FCZ1204727W
2 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
2 ISDN Basic Rate interfaces
1 terminal line
2 Voice FXS interfaces
1 Cellular interface
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
251904K bytes of ATA CompactFlash (Read/Write)
What IOS do you recommend ?
The idea is that this router work as a IP2IP and also have a 3G backup connection (that´s why I need to configure the tunnel).
Best regards
01-06-2011 06:22 PM
Wen
02-02-2011 07:08 AM
Thanks Wen,
you absolutly right.
I change the IOS and it woks just fine.
Best regards,
Nelson Mendes
