07-18-2011 03:24 AM
Hi all,
In an IPSec port to DUT scenario, with Mode-Config set so as the DUT sends the IP address to the port, I get to a situation in which the DUT continuously enter the "Need config/address" state for the port, even if the port sends its ACK packet to every set IP address from the DUT.
The DUT is a Cisco 6500 Version 12.2 (33) SXI3, having Mode-Configuration configured to provide clients with IP addresses from a local pool.
I enabled the "debug crypto isakmp" on Cisco, and below is an extract form the log file:
5d23h: ISAKMP:(80653):Need config/address /* My comments here: This is the first Address configuration message from Cisco to port */
5d23h: ISAKMP: set new node 1768971286 to CONF_ADDR
5d23h: ISAKMP: Sending private address: 94.94.0.164
5d23h: ISAKMP:(80653): initiating peer config to 171.159.1.113. ID = 1768971286
5d23h: ISAKMP:(80653): sending packet to 171.159.1.113 my_port 500 peer_port 500 (R) CONF_ADDR
5d23h: ISAKMP:(80653):Input = IKE_MESG_INTERNAL, IKE_PHASE1_COMPLETE
5d23h: ISAKMP:(80653):Old State = IKE_P1_COMPLETE New State = IKE_CONFIG_MODE_SET_SENT
5d23h: ISAKMP (80653): received packet from 171.159.1.113 dport 500 sport 500 Global (R) CONF_ADDR
5d23h: ISAKMP:(80653):processing transaction payload from 171.159.1.113. message ID = 1768971286
5d23h: ISAKMP: Config payload ACK
5d23h: ISAKMP:(80653):peer accepted the address!
5d23h: ISAKMP:(80653):deleting node 1768971286 error FALSE reason "Transaction mode done"
5d23h: ISAKMP:(80653):Input = IKE_MESG_FROM_PEER, IKE_CFG_ACK
5d23h: ISAKMP:(80653):Old State = IKE_CONFIG_MODE_SET_SENT New State = IKE_P1_COMPLETE
5d23h: ISAKMP: set new node 54789084 to CONF_ADDR
5d23h: ISAKMP:(80653): initiating peer config to 171.159.1.113. ID = 54789084
/* My comments: Here is the first Quick mode packet (IKEv1) from the port */
5d23h: ISAKMP: set new node 1878084416 to CONF_ADDR
5d23h: ISAKMP: set new node -2058471196 to CONF_ADDR
5d23h: ISAKMP:(80653):Sending NOTIFY PROPOSAL_NOT_CHOSEN protocol 3 spi 1240980124, message ID = -2058471196
5d23h: ISAKMP:(80653):purging node -2058471196
5d23h: ISAKMP:(80653):deleting node 1878084416 error FALSE reason "Saved QM no longer needed"
5d23h: ISAKMP (80653): Unknown Input IKE_MESG_INTERNAL, IKE_PHASE1_COMPLETE:state = IKE_CONFIG_MODE_SET_SENT
5d23h: ISAKMP:(80653):Old State = IKE_CONFIG_MODE_SET_SENT New State = KE_CONFIG_MODE_SET_SENT
/* My comments: The port will answer to set address from Cisco */
5d23h: ISAKMP:(80653):processing transaction payload from 171.159.1.113. message ID = 54789084
5d23h: ISAKMP:(80653):deleting node 54789084 error FALSE reason "Transaction mode done"
5d23h: ISAKMP: set new node -317124967 to CONF_ADDR
5d23h: ISAKMP:(80653): initiating peer config to 171.159.1.113. ID = -317124967
5d23h: ISAKMP:(80653):processing transaction payload from 171.159.1.113. message ID = -317124967
5d23h: ISAKMP:(80653):deleting node -317124967 error FALSE reason "Transaction mode done"
From the above debug messages that Cisco produces I can not realize why Cisco resends the IP adderss configuration message for remote peer.
Do you know other methods to use so as to get the reason behind this behavior? Or do you have any explanation to the above behavior?
Thank you,
07-18-2011 04:28 AM
William,
Is this new setup/problem or did this work before?
Can you paste in full debugs and
show run | s crypto
There are a few known problems in mode config like:
So going for latest in SXI might be best.
But anyway if possible I wouldlike to see these debugs fully before we move forward ;]
debug crypto isa
debug crypto isa err
You can use "debug crypto condition peer ipv4" to narrow down the debugs.
Marcin
