Highlighted
Beginner
Cisco AnyConnect and Hyper-V
Hi Guys,
Recently i'm facing some issues with Cisco AnyConnect and Hyper-V. The problem starts when some users install Docker, and this application enable Hyper-V and the Virtual NICs, when this happens, the machine lost relancionship with the domain, because AnyConnect.
Any clue to solve this problem? Can i disable Cisco NAM from the interfaces without problems?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Enthusiast
Re: Cisco AnyConnect and Hyper-V
Go to regedit and serach for below
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall
and search Cisco AnyConnect Network Access Manager then go to the uninstall string like below
MsiExec.exe /X{03E27F04-873F-43B9-96BA-0795BDA325A2}
copy the string and past to windows command prompt like below
MsiExec.exe /X{03E27F04-873F-43B9-96BA-0795BDA325A2} /quiet /norestart
Hope This Helps
Abheesh
3 REPLIES 3
Enthusiast
I suspect the NAM module. If NAM module is there it will try to connect via nam module. Try unistalling NAM module if you are not using any ISE related authentication or posturing.
Hope this Helps
Abheesh
Beginner
Can you help me how to do it, via command line? I need to automate the
docker instalation and in one of thrle steps i will uninstall/disable nam.
Enthusiast
Hope This Helps
Abheesh
