I use AnyConnect as an End-to-Site VPN to connect to my companies network from my home connection.
After resetting my notebook I get disconnects regularly. I then have to reconnect with the VPN manually.
The windows event logs returned this warning and error:
Tunnel level reconnect reason code 13:
Loss of contact with the gateway.
Caching reconnect reason for IPsec
Function: CIPsecTunnelStateMgr::OnTunnelStatusChange
File: IPsecTunnelStateMgr.cpp
Line: 1220
Invoked Function: Tunnel status change callback status
Return Code: -27459567 (0xFE5D0011)
Description: IPSECPROTOCOL_ERROR_IKE_SA_FAILURE
Do you have any idea what this could be or how to fix this?
Does the software produce any logs I can look at?
