10-15-2018 05:33 PM
Hi Everyone,
I have the latest version of Anyconnect downloaded from the IOS Store, version 4.5.0.3050, and the ASA is running version 9.8.3. It is authenticating. I imported the certificate manually via the email attaching and you can see that under the Settings-General-Profile. However, it doesn't show it under the Anyconnect Connection under certificate under Diagnostics. When you go there, it asks you to import and not sure how to go about importing without providing a URL.
Does anyone have any suggestions?
Solved! Go to Solution.
10-15-2018 09:30 PM
10-15-2018 09:30 PM
10-16-2018 08:12 PM
Thank you Francesco, it worked great!
10-17-2018 06:19 AM
