Cisco AnyConnect Secure Mobility Client - Script Problem
Nessie Oswald
I am running ASA 8.4(1) ASDM 6.4 and Anyconnect Client 3.1.05152, and am running into issues where the script is pushed to the client but is not executed.
EnableScripting = true is set in the profile.
I have named my script OnConnect.vbs and I see it getting pushed to the client but not executed.
So any advise on how to solve the issue would be very much appreciated.
Thanks in advance for your replies.
bravotom99
do you have the xml assigned in the group policy on the ASA?  I know the scripting behavior changed between anyconnect 2.5 and 3.1.  AnyConnect 2.5 only required the xml profile locally but 3.1 requires the xml with EnableScripting = true to be assigned to the group policy.
Has miracalously started working so thanks for your reply.
