Ask the Expert- SD-WAN
1406
Beginner
Cisco ASA 5505 IPSec tunnel won't establish until remote site attempts to connect
I have a site to site IPSec tunnel setup and operational but periodically the remote site goes down, because of a somewhat reliable internet connection. The only way to get the tunnel to re-establish is to go to the remote site and simply issue a ping from a workstation on the remote network. We were having this same issue with a Cisco PIX 506E but decided to upgrade the hardware and see if that resolve the issue. It ran for well over a year and our assumtions was that the issue was resolved. I was looking in the direction of the security-association lifetime but if we power cycle the unit, I would expect that it would kill the SA but even after power cycling, the VPN does not come up automatically.
Any assistance would be appreciated.
ASA Version 8.2(1)
hostname KRPS-FW
domain-name lottonline.org
enable password uniQue
passwd uniQue
names
interface Vlan1
nameif inside
security-level 100
ip address 10.20.30.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xxx.xxx.xxx.xxx 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
description Inside Network on VLAN1
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
access-list NONAT extended permit ip 10.20.30.0 255.255.255.0 10.20.20.0 255.255.255.0
access-list NONAT extended permit ip 10.20.30.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list NONAT extended permit ip 10.20.30.0 255.255.255.0 192.168.15.0 255.255.255.0
access-list KWPS-BITP extended permit ip 10.20.30.0 255.255.255.0 10.20.20.0 255.255.255.0
access-list KWPS-BITP extended permit ip 10.20.30.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list KWPS-BITP extended permit ip 10.20.30.0 255.255.255.0 192.168.15.0 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list NONAT
nat (inside) 1 0.0.0.0 0.0.0.0
access-group OUTSIDE_ACCESS_IN in interface outside
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.20.30.0 255.255.255.0 inside
http 10.20.20.0 255.255.255.0 inside
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map DYNMAP 65535 set transform-set ESP-AES-256-SHA
crypto map VPNMAP 1 match address KWPS-BITP
crypto map VPNMAP 1 set peer xxx.xxx.xxx.001
crypto map VPNMAP 1 set transform-set ESP-AES-256-SHA
crypto map VPNMAP 65535 ipsec-isakmp dynamic DYNMAP
crypto map VPNMAP interface outside
crypto isakmp enable outside
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
ssh timeout 5
console timeout 0
management-access inside
tunnel-group xxx.xxx.xxx.001 type ipsec-l2l
tunnel-group xxx.xxx.xxx.001 ipsec-attributes
pre-shared-key somekey
1 REPLY 1
Highlighted
Rising star
Hi there,
I had same issue with PIX 506E and it was not even a circuit issue and I got ride of it and problem got fixed with PIX515E
I don't know, the device is too old to stay alive.
thanks
