Cisco ASA - L2L VPN redundancy between two Sites with dual ISP link in each sites, respectively.
Samir Aliyev
Hi Dear Engineers,
I need to implement L2L VPN redundancy between two Sites with dual ISP link in each sites, respectively.
Please help me for best solution.
I attached  appropriate diagram.
Thanks in advance
Peter Long
No Problem, on each ASA you need to specify BOTH public IP addresses of the other ASA in the cryptomap, and the opposite on the other like so;
crypto map outside_map 1 match address outside_cryptomap
crypto map outside_map 1 set peer 1.1.1.1 2.2.2.2
crypto map outside_map 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5
crypto map outside_map 1 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map interface outside
Then you need a tunnel-group on Each ASA for those IP addresses that are identical, like so
tunnel-group 1.1.1.1 type ipsec-l2l
tunnel-group 1.1.1.1 ipsec-attributes
 pre-shared-key *
tunnel-group 2.2.2.2 type ipsec-l2l
tunnel-group 2.2.2.2 ipsec-attributes
 pre-shared-key *
This assumes you already have a site to site VPN up, and you are just adding the second IP of the ASA at the other end. As usual both sites should be a mirror image.
Cisco ASA 5500 Site to Site VPN (From CLI)
Pete
I've covered this in the link below, but yours just has two ISP's at BOTH ends, the procedure is the same.
Cisco ASA/PIX 8.x: Redundant or Backup ISP Links with VPNs
Pete
But in this config, in case going down of primary link, the vpn tunnel through backup link comes up late (nearly, 30-40 secs.). And customer requires less downtime.  And additionally, when primary link comes back online, (backup link still online),  ASA troubles to create vpn tunnel through primary link.
So, I used different crypto maps with the same interesting traffic, transform set, but with relevant peer address, respectively.  and relevant tunnel-groups, of course.
My sample config is in below. Please, review and comment.
ASA Left side
ASA Version 8.0(2)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0/0
 nameif inside
 security-level 100
 ip address 192.168.250.1 255.255.255.0
interface Ethernet0/1
 nameif ttl
 security-level 0
 ip address 192.168.168.1 255.255.255.0
interface Ethernet0/2
 nameif saturn
 security-level 0
 ip address 192.168.169.1 255.255.255.0
interface Ethernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
access-list test extended permit ip 192.168.250.0 255.255.255.0 10.84.0.0 255.255.255.0
route ttl 10.84.0.0 255.255.255.0 192.168.168.2 1 track 1
route saturn 10.84.0.0 255.255.255.0 192.168.169.2 10
sla monitor 1
 type echo protocol ipIcmpEcho 192.168.168.2 interface ttl
 num-packets 2
 timeout 1000
 frequency 3
sla monitor schedule 1 life forever start-time now
crypto ipsec transform-set test esp-3des esp-sha-hmac
crypto map test 1 match address test
crypto map test 1 set peer 192.168.168.2
crypto map test 1 set transform-set test
crypto map test interface ttl
crypto map test2 1 match address test
crypto map test2 1 set peer 192.168.169.2
crypto map test2 1 set transform-set test
crypto map test2 interface saturn
crypto isakmp enable ttl
crypto isakmp enable saturn
crypto isakmp policy 1
 authentication pre-share
 encryption 3des
 hash md5
 group 2
 lifetime 86400
crypto isakmp policy 65535
 encryption 3des
 hash sha
 group 2
 lifetime 86400
track 1 rtr 1 reachability
tunnel-group 192.168.168.2 type ipsec-l2l
tunnel-group 192.168.168.2 ipsec-attributes
 pre-shared-key *
tunnel-group 192.168.169.2 type ipsec-l2l
tunnel-group 192.168.169.2 ipsec-attributes
 pre-shared-key *
ASA Right Side
ASA Version 8.0(2)
 nameif inside
 security-level 100
 ip address 10.84.0.1 255.255.255.0
 nameif ttl
 security-level 0
 ip address 192.168.168.2 255.255.255.0
 nameif saturn
 security-level 0
 ip address 192.168.169.2 255.255.255.0
 shutdown
 no nameif
 no security-level
 no ip address
access-list test extended permit ip 10.84.0.0 255.255.255.0 192.168.250.0 255.255.255.0
route ttl 192.168.250.0 255.255.255.0 192.168.168.1 1 track 1
route saturn 192.168.250.0 255.255.255.0 192.168.169.1 10
sla monitor 1
 type echo protocol ipIcmpEcho 192.168.168.1 interface ttl
 num-packets 2
 timeout 1000
 frequency 3
crypto map test 1 set peer 192.168.168.1
crypto map test2 1 set peer 192.168.169.1
crypto map test2 interface Saturn
 encryption 3des
 hash sha
 group 2
 lifetime 86400
 encryption 3des
 hash sha
 group 2
 lifetime 86400
tunnel-group 192.168.168.1 type ipsec-l2l
tunnel-group 192.168.168.1 ipsec-attributes
 pre-shared-key *
tunnel-group 192.168.169.1 type ipsec-l2l
tunnel-group 192.168.169.1 ipsec-attributes
 pre-shared-key *
nkarthikeyan
Level 7
Level 7
Hi Samir,
Check my blog with the similar set as per your requirement....
http://cuckoonetworks.blogspot.com/
Just need to fine tune with track/ipsla and dpd config to it to make it a better solution.
Karthik
