Cisco ISR 4321 L2TP Problem
roberthudd
Hi All
This is my first post here so please bear with me.
I am trying to connect an L2TP client to Cisco ISR 4321 router (I have previously done this successfully with 29xx series).  The client connects, the virtual interface comes up, IP address gets assigned and a route for the assigned ip gets added to the routing table just like I expected it to.  When I try to ping the assigned ip fom the ISR router it timesout.  When I try to ping the ISR router from the client it times out.  If I run "debug ip packet" I see the ping from the client on the ISR and I also see the ISR reply but the ping response does not arrive at the client. So all traffic that goes out from the ISR on the virtual interface seems to just disappear.
I have configured L2TP only (no IPSec).
Here is show run
Current configuration : 4687 bytes
! Last configuration change at 12:02:20 UTC Fri Sep 1 2017 by xxx
version 15.5
no platform punt-keepalive disable-kernel-core
hostname sssss
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
aaa new-model
aaa authentication login default local
aaa authentication ppp vpdn local
aaa authorization network default none
aaa session-id common
subscriber templating
vpdn enable
vpdn-group L2TP
 ! Default L2TP VPDN group
 ! Default PPTP VPDN group
 accept-dialin
  protocol l2tp
  virtual-template 1
 no l2tp tunnel authentication
license udi pid ISR4321/K9 sn Fx
username xxxxx password 0 xxxxxxxx
redundancy
 mode none
vlan internal allocation policy ascending
interface Loopback5
 ip address 172.16.254.1 255.255.255.0
interface GigabitEthernet0/0/0
 description Connected to inet
 ip address x.x.x.x 255.255.255.224
 negotiation auto
interface GigabitEthernet0/0/1
 description Connected to xxx
 ip address xxxxxxx
 negotiation auto
 vrf forwarding Mgmt-intf
 no ip address
 negotiation auto
interface Virtual-Template1
 ip unnumbered GigabitEthernet0/0/0
 ip mtu 1460
 no peer default ip address
 ppp mtu adaptive
 ppp authentication chap vpdn
interface Vlan1
 no ip address
 shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 x.x.x.x
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 transport input telnet
end
Any help would be greatly appreciated.
Robert
18 Replies 18
Hi roberthudd,
Are you doing NAT/PAT on ISR 4321 ? If yes, have you configured NAT exemption for subnet assigned to L2TP client?
Spooster IT Services Team
Thanks for the reply.  I am not running any NAT on the 4321.  I actually gave up and tried using an old 2911 with the exact same config and the L2TP session could successfully send and receive traffic.  I guess there is some bug in the 4321.
Robert
alexsoft.16
I have the same problem on my ISR 4321. On 2911 this configuration work well. I still can not find a solution.
Here's how I was able to work around it.
first from the Privileged EXEC mode, enter
license right-to-use move appxk9
Then from the Global config mode, enter
license boot level appxk9
Save config and reload the router for the change to take effect.
I hope this helps someone who's facing this same issue in the feature.
Cheers
Did it really worked for you? It did not work for me
15305770925z
You'll need to active the feature license called "appxk9" to forward l2tp traffic.
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/guide/isr4400swcfg/bm_isr_4400_sw_config_guide_chapter_0101.html#concept_EE11CBA65D814447BD6913EF89E8D0C3
In Cisco 4000 Series ISR, although L2TPv2 sessions comes up without appxk9, you need the appxk9 license for the traffic to go through the sessions. You also need the appxk9 license to apply the QoS policies to the L2TPv2 sessions.
#show license feature
Feature name Enforcement Evaluation Subscription Enabled RightToUse
appxk9 yes yes no yes yes
Hope this helps.
Yes, it works fine. Could you please post show version and show license to see this feature is enabled or not?
Thanks for replying. Find below
Stef4321#sh ver
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
appxk9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           appxk9           RightToUse       appxk9
uck9             None             None             None
securityk9       None             None             None
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4321/K9 (1RU) processor with 1648789K/6147K bytes of memory.
Processor board ID FDO2132A086
6 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3223551K bytes of flash memory at bootflash:.
Stef4321#sh lic
Index 1 Feature: appxk9
        Period left: Life time
        License Type: RightToUse
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Low
Index 2 Feature: uck9
        License State: Active, Not in Use, EULA accepted
Index 3 Feature: securityk9
Index 4 Feature: ipbasek9
        License Type: Permanent
        License Priority: Medium
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
        License Count: 0/0  (In-use/Violation)
Index 8 Feature: hseck9
Index 9 Feature: throughput
Index 10 Feature: internal_service
Additionally
Stef4321#sh lic fea
uck9 yes yes no no yes
securityk9 yes yes no no yes
ipbasek9 no no no yes no
FoundationSuiteK9 yes yes no no yes
AdvUCSuiteK9 yes yes no no yes
cme-srst yes yes no no yes
hseck9 yes no no no no
throughput yes yes no yes yes
internal_service yes no no no no
Thanks for your information. Looks like securityk9 is not enabled. I assume you are using L2tp, you need this to be enabled. Try PPTP if you do not want to enable securityk9.
Yes I'm using L2TP and the securityk9 is now enable as below. Still does not work. Any suggestions please?
vpdn enable
vpdn-group 1
accept-dialin
protocol any
virtual-template 1
l2tp tunnel timeout no-session 15
ip mtu adjust
ip unnumbered GigabitEthernet0/0/1
ip nat inside
ip tcp adjust-mss 1400
peer default ip address pool vpn1
no keepalive
ppp authentication pap chap ms-chap ms-chap-v2 eap
ip virtual-reassembly
ip local pool vpn1 10.0.5.6 10.0.5.7
Stef4321#sh lic fea
securityk9 yes yes no yes yes
PS: I can connect but cannot ping any device on the network, not even the router itself
PS2: I'm using PPTP :) Sorry! I lost track due to many tests
