cisco router 1921 internet problem with vpn site to site connection
Fatouh3366
I have dsl connection from TE-data from 3com modem in 2 sites. and I have 2 cisco routers 1921 and there is a vpn site to site between them and
the VPN connection is working good. and i configured PAT on one of them to allow the users access the internet but tere is a problem:
all users can ping any public ip
all users can ping any URL
but there is no browsing of the internet
and this is the configuration
NOZHA#sh run
Building configuration...
Current configuration : 2425 bytes
! Last configuration change at 11:24:08 UTC Thu Sep 20 2012
version 15.0
hostname NOZHA
boot-start-marker
boot-end-marker
enable secret 5
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool 1
network 192.168.40.0 255.255.255.0
default-router 192.168.40.1
dns-server 4.2.2.2 8.8.8.8
lease infinite
ip domain name shady2012
license udi pid CISCO1921/K9 sn FCZ1432C5KM
license boot module c1900 technology-package securityk9
redundancy
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
crypto isakmp key shady2012 address 81.10.xxx.yy
crypto ipsec transform-set shady2012 esp-aes esp-sha-hmac
crypto map s2s-VPN 150 ipsec-isakmp
set peer 81.10.xxx.yy
set pfs group2
match address s2s-vpn-obour
interface GigabitEthernet0/0
mtu 1000
ip address 41.41.xx.yy 255.255.255.252
ip nat outside
ip nat enable
ip virtual-reassembly
duplex auto
speed auto
crypto map s2s-VPN
interface GigabitEthernet0/1
ip address 192.168.40.1 255.255.255.0
ip nat inside
ip nat enable
duplex auto
speed auto
ip default-gateway (41.41.xx.yy)next hop
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat source list mypool interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 41.41.xx.yy
ip route 192.168.20.0 255.255.255.0 (41.41.xx.yy) next hop
ip route 192.168.30.0 255.255.255.0 (41.41.xx.yy) next hop
ip access-list extended mypool
deny ip 192.168.21.0 0.0.0.255 192.168.20.0 0.0.0.255
deny ip 192.168.21.0 0.0.0.255 192.168.30.0 0.0.0.255
deny ip 192.168.40.0 0.0.0.255 192.168.20.0 0.0.0.255
deny ip 192.168.40.0 0.0.0.255 192.168.30.0 0.0.0.255
permit ip any any
ip access-list extended s2s-vpn-obour
permit ip 192.168.40.0 0.0.0.255 192.168.30.0 0.0.0.255
permit ip 192.168.21.0 0.0.0.255 192.168.20.0 0.0.0.255
permit ip 192.168.30.0 0.0.0.255 192.168.40.0 0.0.0.255
permit ip 192.168.20.0 0.0.0.255 192.168.21.0 0.0.0.255
permit ip 192.168.40.0 0.0.0.255 192.168.20.0 0.0.0.255
permit ip 192.168.21.0 0.0.0.255 192.168.30.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
password
login
scheduler allocate 20000 1000
end
if any one have answer please reply ASAP
Jennifer Halim
When you say can ping any URL, i am assuming that you are pinging the FQDN, ie: it does resolve to an ip address, right?
If you disable the VPN, can you browse to the internet?
Do you have any proxy server or anything that might be blocking browsing?
What error message do you get on your web browser?
Do you also try different web browser and none works?
Jennifer Halim
