Ask the Expert- SD-WAN
2285
Highlighted
Beginner
Cisco VTI and IPSec (IKE Phase2) SA proposal configuration.
Hi there,
I'd have a question over the configuration option for Virtual Tunnel Interface (VTI) feature. I have a Cisco IOS router, which terminates customers with individual tunnel interfaces. The issue I now have is that how can I specify 'interesting' traffic on the IPsec SA (IKE Phase2) security association proposal. The configuration on the router is made by crypto profiles like this:
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp profile ISAKMP_PHASE1_PARAMETERS
   keyring PRESHARED_KEYS
   match identity address 1.2.3.4 255.255.255.255
crypto keyring PRESHARED_KEYS
pre-shared-key address 1.2.3.4 key xyz
crypto ipsec transform-set VPN-TRANSFORMSET esp-3des esp-sha-hmac
crypto ipsec profile ISAKMP_PHASE2_TUNNEL
set transform-set VPN-TRANSFORMSET
set pfs group2
set isakmp-profile ISAKMP_PHASE1_PARAMETERS
interface Tunnel1
ip address 10.10.10.1 255.255.255.252
ip mtu 1450
tunnel source Loopback1
tunnel destination 1.2.3.4
tunnel mode ipsec ipv4
tunnel protection ipsec profile ISAKMP_PHASE2_TUNNEL
Now when I look at the output of command "show crypto ipsec sa int tu1" I get the following:
interface: Tunnel1
    Crypto map tag: Tunnel1-head-0, local addr x.x.x.x
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
   remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
   current_peer 1.2.3.4 port 500
     PERMIT, flags={origin_is_acl,}
However, the peer on the other side don't accept the proposal, since he would like to have specific IP subnets on the IPSec SA proposal parameters. He'd accept the policy if the local remote identity proxies would be for example 192.168.10.0/255.255.255.0/0/0 (local) and
192.168.200.0/255.255.255.0/0/0 (remote).
Is there any IOS configuration options for configuring the 'interesting' traffic on the crypto profile? With the crypto map -based configuration we can specify the interesting traffic with an ACL under the crypto map configuration section.
I'm running IOS version 15.1(4)M with Advanced IP Services feature set.
1 ACCEPTED SOLUTION
SVTI will always want to negotiatiate any any as traffic selectors.
What you MIGHT be looking for is multi-SA DVTI configuration, in which remote end could say which proxy identities it would like to encrypt. (Supported as of 15.2M/T)
The ceveat of such configuration is unfortunately that remote end needs to initiate negotiation.
M.
4 REPLIES 4
M.
Beginner
Hi Marcin and thanks for the reply.
I was hoping for another solution, but I guess this could be feature to look after in the near future. Hopefully Cisco would create a better solution for this kind of issue.
The solution exists forever it's called crypto maps :-)
In the meantime, Flex VPN is taking majority of our effort. I haven't seen a limitation in this regard there. However it does use IKEv2.
Beginner
Well, yeah... Initially I wanted to move away from legacy crypto map configurations by using VTI, but it turned out so that it was the only way dealing with the issue I had. So I got 360 degrees on crypto maps
Anyways, thanks for the tips.
