Client VPN connectivity issues
GrahamB_SEMC
Hello folks,
I posted a discussion earlier detailing my problem which got some help. I applied the user's fix and seemingly had my configuration working so I accepted the answer. However, after disconnecting/reconnecting the VPN I am faced with the same problem again. He had me change some nat rules which, once applied allowed me to connect to RDP. Once disconnecting/reconnecting the original issue occurred again.
The Problem: When using IPSec Remote Access VPN configuration I am unable to ping or connect with RDP/VNC protocols. At times I get a single ping response but I can't understand why that would happen if I cannot establish any other connections.
Details;
- Router is a Cisco ASA 5505 with ASDM 6.4
- Internal VLAN is 192.168.15.0/24, has DHCP enabled
- All current internal hosts have static addresses somewhere near 192.168.15.100-120 with 192.168.15.1 configured as a gateway
- VPN Users receive a 192.168.15.200-250 address
- Cisco VPN Client is used to connect and there are no network connectivity issues between my remote computer and the ASDM application
My Configuration:
Result of the command: "show config"
: Saved
: Written by enable_15 at 15:06:09.524 CDT Mon Sep 9 2013
ASA Version 8.2(5)
hostname host
enable password D37rIydCZ/bnf1uj encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 192.168.15.0 inside-network description Internal Network devices
ddns update method DDNS_Update
ddns both
interval maximum 0 4 0 0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
description VLAN to inside hosts
nameif inside
security-level 100
ddns update hostname 0.0.0.0
ddns update DDNS_Update
dhcp client update dns server both
ip address 192.168.15.1 255.255.255.0
interface Vlan2
description External VLAN to internet
nameif outside
security-level 0
ip address xx.xx.xx.xx 255.255.255.248
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns domain-lookup inside
dns server-group DefaultDNS
name-server 216.221.96.37
name-server 8.8.8.8
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
port-object eq https
access-list outside_access_in extended permit icmp any interface inside
access-list outside_access_in extended permit ip 192.168.15.192 255.255.255.192 any
access-list Remote_splitTunnelAcl standard permit inside-network 255.255.255.0
access-list inside_nat0_outbound extended permit ip inside-network 255.255.255.0 192.168.15.192 255.255.255.192
access-list inside_access_in extended permit ip 192.168.15.192 255.255.255.192 any
access-list inside_access_in extended permit ip interface inside interface inside
access-list inside_access_in extended permit ip any 192.168.15.192 255.255.255.192
access-list inside_access_in extended permit icmp any any
access-list inside_access_out extended permit icmp inside-network 255.255.255.0 any
access-list inside_access_out extended permit ip 192.168.15.192 255.255.255.192 any
access-list inside_access_out extended permit ip inside-network 255.255.255.0 192.168.15.192 255.255.255.192
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool VPN_IP_Pool 192.168.15.200-192.168.15.250 mask 255.255.255.0
ipv6 access-list inside_access_ipv6_in permit ip interface inside interface inside
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any echo-reply inside
icmp permit any echo-reply outside
icmp permit any outside
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
access-group inside_access_in in interface inside
access-group inside_access_ipv6_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 xx.xx.xx.xx 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http inside-network 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
dhcpd auto_config outside
dhcpd address 192.168.15.200-192.168.15.250 inside
dhcpd enable inside
no threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ntp server 192.168.15.101 source inside
ntp server 192.168.15.100 source inside prefer
webvpn
group-policy Remote internal
group-policy Remote attributes
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Remote_splitTunnelAcl
username StockUser password t6a0Nv8HUfWtUdKz encrypted privilege 0
username StockUser attributes
vpn-group-policy Remote
tunnel-group Remote type remote-access
tunnel-group Remote general-attributes
address-pool VPN_IP_Pool
default-group-policy Remote
tunnel-group Remote ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:f1351b0e8517ff0725884ef5f6e3abe7
npokhriy
Are you able to ping the  inside interface of ASA?
I would suggest you to change the address-pool for clients and then test the issue.
Naresh
Yes I am able to ping 192.168.15.1 reliably.
I'm not extremely familiar with Cisco devices and configuring, how would changing the address pool help resolve this issue?
