1805
Highlighted
clientless ssl vpn homepage after login problem
Hi all,
I have a problem with my clientless vpn portal.
I need to configure that when a user logs in through the portal, something that works just fine, that he ends up on the homepage.
Right now he ends up immediatly on the anyconnect button.
With the homepage I do mean the first button that says "Home".
Users must be able to click on the "Web Applications", below "Home".
Below "Web Applications" users must have their "Anyconnect" button aswell.
First of all I wasn't able to make the portal display the "Anyconnect" button in the menu.
Then after a while, I figured out that when de Dynamic Access Policy said "Unchanged" on the "Access Method" page.
When changing that parameter to "Anyconnect client" the portal is no portal anymore, I immediatly end up on the anyconnect client start.
When selecting "Web-Portal" I get the portal page, but the anyconnect menu is missing.
When selecting "Both-Default-Web-Portal" I get the anyconnect button, and all other menus, which is good.
But, I want the home button to be the default.
And not the anyconnect button, after logging in you immediatly get the start anyconnect page.
And then last but not least, when selecting "Both-Default-Anyconnect" you login to the webportal, anyconnect starts immediatly from the menu.
Something we want the end user to do manually (Click "Start Anyconnect") I mean!
I'm pretty sure the DAP is forcing that because of the options above.
But when selecting unchanged or anything that doesn't include Anyconnect, then the anyconnect button is gone...
I don't know what I can do to change that.
Am I missing something??
I would say DAP isn't needed, but when I set everything to default in the default DAP, then the anyconnect button is gone in the menu...
Kind regards,
Robin
Here's my configuration:
group-policy GP_company_intranet_portal attributes
wins-server value x.x.x.x
dns-server value x.x.x.x
vpn-tunnel-protocol ssl-client ssl-clientless
split-tunnel-policy tunnelall
default-domain value company.local
address-pools value IPP_SSLVPN01
webvpn
  url-list value BML_company_intranet_portal
  http-proxy disable
  anyconnect keep-installer installed
  anyconnect ask enable default webvpn
  customization value CO_company_intranet_portal
  http-comp gzip
  hidden-shares none
  activex-relay enable
  file-entry disable
  file-browsing disable
  url-entry disable
  smart-tunnel auto-signon disable
tunnel-group TG_company_portal_localauth type remote-access
tunnel-group TG_company_portal_localauth webvpn-attributes
customization CO_company_intranet_portal
group-url https://portal.company.be enable
username testaccount password xxxxxxxxxx encrypted privilege 0
username testaccount attributes
vpn-group-policy GP_company_intranet_portal
password-storage disable
group-lock value TG_company_portal_localauth
service-type remote-access
Troubleshooting when logged in, just to verify if the right group-policy is being used:
FW-company# show vpn-sessiondb webvpn
Session Type: WebVPN
Username     : testaccount              Index        : 510
Public IP    : x.x.x.x
Protocol     : Clientless
License      : AnyConnect Premium
Encryption   : 3DES                   Hashing      : SHA1
Bytes Tx     : 114897                 Bytes Rx     : 16087
Group Policy : GP_company_intranet_portal
Tunnel Group : TG_company_portal_localauth
Login Time   : 14:50:56 GMT+2 Thu Oct 25 2012
Duration     : 0h:00m:03s
Inactivity   : 0h:00m:00s
NAC Result   : Unknown
VLAN Mapping : N/A                    VLAN         : none
1 ACCEPTED SOLUTION
Hi Robin,
You could try:
1- Please remove / disable the DAP rules and only keep the default one with default action and settings (continue). This in order to exclude DAPs as the root cause.
2- group-policy GP_company_intranet_portal attributes
     webvpn
          anyconnect ask none default webvpn
Let me know how it goes.
HTH.
Portu.
Please rate any helpful posts
3 REPLIES 3
Hi Robin,
You could try:
     webvpn
HTH.
Portu.
Hi jportugu,
I can't believe it, i serieously though I already did that... And that removed my anyconnect button from the menu.
Which is why I started playing with the DAP function in the first place.
I tried your suggestion and that now works..
Thanks!
The only new problem now is that my bookmarks aren't showing up anymore now.
But that must be a different problem I guess.
Might be DAP related again?
Result: I activated under the default DAP: "Bookmarks" ==> "Enable bookmarks"
Now everything works as it is supposed to...
Really strange though... I thought I did that already...
Thanks jportugu!!
Kind regards,
Robin
Robin,
Great news
Thanks for counting on this great Support Community!
