08-15-2010 08:40 AM - edited 02-21-2020 04:47 PM
First off, forgive me, I know very little about VPN. I was issued a very slow laptop with AnyConnect installed on it to access my desktop at work for the purposes of SQL 2008 design. I work for the State and they will not provide any support for other than their machine. From home I'm running an intel based iMac with OS X v10.5.7.
This is what I know:
Questions
Thank you for any help. I have been watching text boxes crawl across my screen for months and any help would be appreciated.
Tom
08-15-2010 09:58 AM
"I tried to use the vpn access in the Mac Network settings. I have no shared secret of know how to authenticate my machine"
- You are looking at the IPSec Client on the MAC the shared secret is for the IPSec group authentication and not relevant for your case since AnyConnect is SSL VPN.
Questions
-- Unless you have a CCO login/password tied to a support contract I don't think you will be able to download from Cisco.
-- No you don't other than the hostname/address of the VPN head end. If they use an alias it may be tougher to determine where your connected. You can find it in the Client Statistics tab.
On the MAC open up the browser and connect to the same address you use the Windows AnyConnect Client to connect - hopefully for you they reveal that in the Client.. If it says mycompany.com then in the browser use https://mycompany.com and see if they permit web portal logins. If they do they may have the MAC Client available via Web Launch.. What this means that when you connect to the VPN headend your MAC will be scanned to determine the OS and if they have a regular expression defined the correct MAC client (Intel or power pc) may be pushed down to you. The reason I am suggesting this is that we don't "officially support" Mac's YET but we do offer it (and I use one) and that is how I distribute it.
Good luck.
Best regards,
Paul
02-14-2011 05:57 AM
Hello Paul,
If I understand what you are saying our UC560 which is acting as our firewall as well should have the MAC AnyConnect client installed somewhere and the UC560 would 'check' the iMac as it attempts to connect?
best regards,
Barry
"when you connect to the VPN headend your MAC will be scanned to determine the OS and if they have a regular expression defined the correct MAC client (Intel or power pc) may be pushed down to you."
