Connecting to a client who is connected using AnyConnect
Hu371
I have a ASA setup with remote access SSL VPN. Clients are using AnyConnect and it's working. But I'm not able to connect to VPN clients from the management network, that is behind ASA-s Inside network.
The solution would need an access to VPN client for managing Windows Updates and other settings from one central point.
Right not if i'm trying to ping VPN clients (using VPN IP pool 192.168.x.0/24) from the central management network,  and I get a log message from ASA  "Routing failed to locate next hop from UDP from Outside: 192.168.x.10/17500 to Inside: 192.168.X.255/17500.
What is the best practice to set up this kind of a solution where there is need to manage client computers centrally(when the clients have established a remote access VPN connection using AnyConnect)?
Hi Harri,
Could you please provide the following information?
1- show run ip local pool.
2- IP addres of the management network.
3- "show run nat"
Thanks.
Portu.
