Dialer interface
kelvin-yeo
Hi Pros,
Just some concept questions.
How does a PRI router hunt for the correct dialer interface to serve the incoming calls.
Correct me. 1 dialer interface for each peer. This interface will serve both incoming and outgoing calls
Cheers guys,
kelvin
lgijssel
Level 9
Level 9
Mostly you use authentication on incoming calls.
This ppp userid also provides the link to a specific dialer interface.
Leo
lgijssel
Level 9
Level 9
Leo
