06-21-2011 01:48 AM
Hi there,
i have here some old 3640, that was running before with an old isdn multiplexer for a dialin solution.
Due to that only a few users use this dialin, the expensive isdn multiplexer is no longer needed and now a 4 Port BRI Card is inside.
The problem is actually, that the isdn dialin works but not the dialin for analog users (via the digital modems)
System and IOS:
cisco 3640 (R4700) processor (revision 0x00) with 60416K/5120K bytes of memory.
4 ISDN Basic Rate interface(s)
18 terminal line(s)
IOS (tm) 3600 Software (C3640-IS-M), Version 12.2(46a),
controller E1 2/0
pri-group timeslots 1-31
controller E1 2/1
interface Loopback1
description >>>Loopback for Dialer 10-30<<<
ip address 192.168.5.1 255.255.255.0
interface Loopback10
ip address 10.1.1.1 255.255.255.0
interface Ethernet0/0
description > internal Network <
ip address 172.16.1.11 255.255.255.0
no ip redirects
ip nat inside
full-duplex
interface Serial2/0:15
description > S2M Dial-backup <
ip unnumbered Loopback1
encapsulation ppp
no logging event link-status
load-interval 30
no keepalive
dialer idle-timeout 3600
dialer enable-timeout 3
dialer-group 1
no snmp trap link-status
isdn switch-type primary-net5
isdn incoming-voice modem
isdn send-alerting
peer default ip address pool isdn
no fair-queue
no cdp enable
ppp callback accept
ppp authentication ms-chap chap pap callin s2000
ppp multilink
interface Group-Async1
description connected to Dial-inPCs(modem)
encapsulation ppp
no ip split-horizon
ip tcp header-compression
no ip mroute-cache
dialer in-band
dialer idle-timeout 36000
async mode dedicated
peer default ip address pool analog
no fair-queue
pulse-time 1
group-range 97 114
ip local pool isdn 172.25.20.33 172.25.20.62
ip local pool analog 172.25.20.65 172.25.20.91
isdn switch-type basic-net3
interface Loopback1
no ip redirects
ip nat inside
full-duplex
interface BRI2/0
description > ISDN 1 <
encapsulation ppp
load-interval 30
no keepalive
dialer-group 1
isdn send-alerting
no fair-queue
no cdp enable
ppp callback accept
ppp multilink
interface BRI2/1
description > ISDN 2 <
encapsulation ppp
load-interval 30
no keepalive
dialer-group 1
isdn send-alerting
no fair-queue
no cdp enable
ppp callback accept
ppp multilink
interface BRI2/2
description > empty <
encapsulation ppp
load-interval 30
no keepalive
shutdown
dialer-group 1
isdn send-alerting
no fair-queue
no cdp enable
ppp callback accept
ppp multilink
interface BRI2/3
encapsulation ppp
load-interval 30
no keepalive
shutdown
dialer-group 1
isdn send-alerting
no fair-queue
no cdp enable
ppp callback accept
ppp multilink
encapsulation ppp
no ip split-horizon
no ip mroute-cache
dialer in-band
no fair-queue
pulse-time 1
group-range 97 114
Mar 16 11:44:31: CCBRI_Go Fr L3 pkt (Len=41) :
Mar 16 11:44:31: 5 1 8C 90 A1 4 3 90 90 A3 18 1 89 1E 2 80 83 6C C 21 83 32 31 30 32 39 34 39 36 37 33 70 8 C1 31 33 35 30 36 32 30
Mar 16 11:44:31:
Mar 16 11:44:31: ISDN BR2/0: Incoming call id = 0x000D, dsl 16
Mar 16 11:44:31: ISDN BR2/0: LIF_EVENT: ces/callid 1/0xD HOST_INCOMING_CALL
Mar 16 11:44:31: ISDN BR2/0: HOST_INCOMING_CALL: (non-POTS) VOICE
Mar 16 11:44:31: ISDN BR2/0: HOST_INCOMING_CALL: (1) call_type = VOICE
Mar 16 11:44:31: ISDN BR2/0: HOST_INCOMING_CALL: voice_answer_data = FALSE call type is VOICE ALAW
Mar 16 11:44:31: ISDN BR2/0: Event: Received a VOICE call from <CALLER-NUMBER-DELETED> on B1 at 64 Kb/s
Mar 16 11:44:31: ISDN BR2/0: Event: Accepting the call id 0xD
Mar 16 11:44:31: ISDN BR2/0: RM returned call_type 1 resource type 0 response 1
Mar 16 11:44:31: CCBRI_Go Fr Host InPkgInfo (Len=9) :
Mar 16 11:44:31: 7 10 1 0 D 3 18 1 89
Mar 16 11:44:31:
Mar 16 11:44:31: BRI2/0:1: Enabled channel B1
Mar 16 11:44:31: BRI2/0: Wrote command 0x14 to SID
Mar 16 11:44:31: ISDN BR2/0: VOICE_ANS Event: call id 0xD, bchan 0, ces 1
Mar 16 11:44:31: ISDN BR2/0: isdn_send_connect(): msg 4, call id 0xD, ces 1 bchan 0, call type VOICE
Mar 16 11:44:31: CCBRI_Go Fr Host InPkgInfo (Len=6) :
Mar 16 11:44:31: 3 10 1 0 D 0
Mar 16 11:44:31:
Mar 16 11:44:31: 4 10 1 0 D 0
Mar 16 11:44:31:
Mar 16 11:44:31: CCBRI_Go Fr L3 pkt (Len=4) :
Mar 16 11:44:31: F 1 8C 92
Mar 16 11:44:31:
Mar 16 11:44:31: ISDN BR2/0: LIF_EVENT: ces/callid 1/0xD HOST_CONNECT
Mar 16 11:44:31: ISDN: get_isdn_service_state(): idb 0x61FBAAC0 bchan 2 is_isdn 1 Not a Pri
Mar 16 11:44:31: ISDN BR2/0: Event: Connected to <CALLER-NUMBER-DELETED> on B1 at 64 Kb/s
Mar 16 11:45:12: CCBRI_Go Fr L3 pkt (Len=12) :
Mar 16 11:45:12:
Mar 16 11:45:12: 45 1 8C 96 8 2 80 90 1E 2 82 88
Mar 16 11:45:12: ISDN BR2/0: LIF_EVENT: ces/callid 1/0xD HOST_DISCONNECT
Mar 16 11:45:12: ISDN BR2/0: Event: Call to <unknown> was hung up.
Mar 16 11:45:12: ISDN BR2/0: process_disc_ack(): call id 0xD, ces 1, call type VOICE cause 0x0
Mar 16 11:45:12: ISDN: get_isdn_service_state(): idb 0x61FBAAC0 bchan 2 is_isdn 1 Not a Pri
Mar 16 11:45:12: CCBRI_Go Fr Host InPkgInfo (Len=10) :
Mar 16 11:45:12: 6 10 1 0 D 0 8 2 0 8
Mar 16 11:45:12:
Mar 16 11:45:12: ISDN BR2/0: VOICE_HANGUP Event: call id 0xD, bchan 0, ces 1, cause 0x10
Mar 16 11:45:12: ISDN BR2/0: Event: Voice hangup call to call id 0xD
Mar 16 11:45:12: BRI2/0:1: Disabled channel B1
Mar 16 11:45:12: BRI2/0: Wrote command 0x15 to SID
Mar 16 11:45:12: CCBRI_Go Fr L3 pkt (Len=4) :
Mar 16 11:45:12: 5A 1 8C 99
Mar 16 11:45:12:
Mar 16 11:45:12: ISDN BR2/0: LIF_EVENT: ces/callid 1/0xD HOST_DISCONNECT_ACK
Mar 16 11:45:12: ISDN BR2/0: HOST_DISCONNECT_ACK: call type is VOICE
Mar 16 11:45:12: ISDN BR2/0: HOST_DISCONNECT_ACK: VOICE ERROR: NULL VDEV Common(0xFC): bchan 0, call id D
06-21-2011 03:32 AM
Really old stuff but it should still work.
Is the modem module still in slot 3?
Lines configured like below?
line 97-114
! --- This must match the group-range in the Group-Async Interface
! --- Use the show line command to determine which lines are to be configured for dialin
autoselect during-login
autoselect ppp
modem Dialin
Please check the rest of the prerequisites listed in the link:
regards,
Leo
06-21-2011 07:33 AM
Hi Leo,
the lines are matching with the lines specified in the Async intfce. as you can see below.
line 97 114
script modem-off-hook offhook
script callback callback
modem autoconfigure type mica
exec-character-bits 8
special-character-bits 8
transport preferred none
no ip tcp input-coalesce-threshold
autoselect ppp
hold-character 0
i added in the actual config the "modem dialin" command to the lines 97 114.
Let's see if this helps.
Cheers
12-20-2011 08:43 AM
I have the same problem - how did you resolve that issue?
04-19-2012 02:04 AM
the problem was never solved.
The BRI was not able to speak with the digital modem card/module, maybe there was some problem with the eeprom software version on the BRI.
BR
stefan
