02-20-2019 03:03 AM - edited 02-21-2020 09:34 PM
Dear all,
I am trying to integrate DMVPN and L2TP because i have different vendor devices.I have two DC.DC1 (Spoke4 ) is using non cisco. DC2 is using cisco.my spoke site are need to connect DC1 and DC2 .so i mix DMVPN and l2tp(IPSEC) .Please see the below diagram.
I am using delay value to choose the tunnel priority.But if i integrate l2tp with DMVPN is down. Please see error log.
How can i solve this problem.DC1 l2TP is already running IPSEC in production.now i need to do DMVPN only.but i worry it will be conflict each other. Please advice how to avoid ?
02-20-2019 03:51 AM
The error you are receiving is usually when the identity of the peer does not match what is expected. As you are matching on a certificate map for the remote identity, have you tried specifying the local identity as DN rather than FQDN.
02-20-2019 06:21 PM - edited 02-20-2019 09:49 PM
HI RJI,
i changed local fqdn to local dn. but still got error.Before applying l2tP/IPSec from HUB to spoke by using VTI ,my dual home dmvpn is working fine. After applying l2tP/IPSec to spoke4 from HUB,dmvpn is down .Even though i already deleted VTI tunnel in HUB dmvpn is still down and show below message.
*Feb 21 09:15:36.455: %BGP-5-NBR_RESET: Neighbor 110.110.110.1 reset (Peer close d the session)
*Feb 21 09:15:36.459: %BGP-5-ADJCHANGE: neighbor 110.110.110.1 Down Peer closed the session
*Feb 21 09:15:36.463: %BGP_SESSION-5-ADJCHANGE: neighbor 110.110.110.1 IPv4 Unic ast topology base removed from session Peer closed the session
*Feb 21 09:15:36.475: %BGP-5-NBR_RESET: Neighbor 150.150.150.1 reset (Peer close d the session)
*Feb 21 09:15:36.479: %BGP-5-ADJCHANGE: neighbor 150.150.150.1 Down Peer closed the session
*Feb 21 09:15:36.483: %BGP_SESSION-5-ADJCHANGE: neighbor 150.150.150.1 IPv4 Unic ast topology base removed from session Peer closed the session
*Feb 21 09:15:36.971: %BGP-5-ADJCHANGE: neighbor 150.150.150.1 Up
*Feb 21 09:15:36.975: %BGP-5-ADJCHANGE: neighbor 110.110.110.1 Up
Cbtme-Hub#
*Feb 21 10:19:29.347: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=110.110.110.1, prot=50, spi=0x93165353(2467713875), srcaddr=120.120.120.1, input interface=FastEthernet0/0
SPOKE 4 Config
cbtme-spoke4#sh run
ip domain name crypto.local
crypto pki trustpoint my-ca
enrollment terminal
serial-number none
fqdn cbtme-spoke4.crypto.local
ip-address none
subject-name cn=cbtme-spoke4.crypto.local
revocation-check none
crypto pki certificate map CERT-MAP 10
subject-name co crypto.local
crypto ikev2 proposal DMVPN-proposal
encryption aes-cbc-256
integrity sha256
group 14
crypto ikev2 policy DMVPN-POLICY
crypto ikev2 profile DMVPN-PROF
match certificate CERT-MAP
identity local dn
authentication remote rsa-sig
authentication local rsa-sig
crypto ipsec transform-set DMVPN-TS esp-aes 256 esp-sha256-hmac
mode tunnel
crypto ipsec profile DMVPN-IPSEC
set transform-set DMVPN-TS
set ikev2-profile DMVPN-PROF
interface Tunnel1
ip address 2.2.2.20 255.255.255.0
tunnel source FastEthernet2/1
tunnel mode ipsec ipv4
tunnel destination 150.150.150.1
tunnel protection ipsec profile DMVPN-IPSEC
interface FastEthernet2/1
ip address 140.140.140.1 255.255.255.0
speed auto
duplex auto
router bgp 104
bgp log-neighbor-changes
network 140.140.140.1 mask 255.255.255.255
neighbor 140.140.140.2 remote-as 100
cbtme-spoke4#
02-21-2019 01:42 AM
02-21-2019 03:06 AM - edited 02-21-2019 03:59 AM
Hi RJI,
Do you want me create two trust-point for HUB and Spoke ?
i need to use VTI for one CA and DMVPN for one CA ,correct ?
I didn't know how use PSK for the VTI ? let me know ? PSK mean preshare key ? it is correct Preshare key is working. i got error in CA only.
can i use same certificate authentication method for two CA ?
eg.
crypto pki certificate map DC1-MAP 10
crypto pki certificate map DC2-MAP 11
do i need to use different keypair for each CA ? i already created VTI links without keypair in production.
let me know can create two ca witout keypair ? i need to create keypair in rsa key generate ? or i need to type command in trustpoint ? can i do without keypair ?
crypto key generate rsa modulus 2048 label test
OR
rsakeypair test
02-21-2019 04:10 AM
Hi, Yes PSK = Pre-shared key. When you say this worked, did you get the VTI and DMVPN working at the sametime? If yes, this it wanted to confirm, this would indicate the tunnel configuration is correct and the issue is related to the certificate matching.
In your example:-
....the subject is the same, so will never match the 2nd certificate match, so will therefore never match the other ikev2 profile.
If you need to use certificate authentication for the VTI, then use a seperate CA, with a unique subject-name (not crypto.local) so therefore the hub will be able to distiguish the correct certificate to use with the correct tunnel.
02-21-2019 04:38 AM
Hi ,
do i need to use different keypair for each CA ? i already created VTI links without keypair in production. so i am dificult to recreate trustpoint with keypair.
OR
rsakeypair test
You advice to use unique subject name for VTI ? So i can still use co =crypto.local for DMVPN ,Correct ?
i will double check for preshare and i will reply you.
02-21-2019 04:53 AM
Hi, Give me an hour and I'll lab it for you and give you the exact syntax.
Rob
02-21-2019 06:52 AM
Ok, configuration below. Bear in mind you can only run 1 CA on a Cisco router, therefore if the HUB is already the CA for the DMVPN you cannot create another CA on it. You would have to create the CA on the VTI spoke and enroll the HUB router.
Essentially all I have done it duplicate the same configuration but used DC2 instead of DC1, this is to make the configuration unique and therefore not match the wrong certificate map/ikev2 profile)
The configuration below is for the HUB
crypto key generate rsa usage-keys label DC1_CA modulus 2048 exportable
crypto key generate rsa usage-keys label DC2_CA modulus 2048 exportable
crypto pki trustpoint DC1_TP
rsakeypair DC1_CA
crypto pki certificate map DC1_MAP 10
issuer-name co dc1.local
crypto ipsec transform-set DC1_TSET esp-gcm
mode tunnel
crypto ipsec profile DC1_IPSEC_PROFILE
set transform-set DC1_TSET
set ikev2-profile DC1_PROFILE
crypto ikev2 profile DC1_PROFILE
match certificate DC1_MAP
identity local dn
crypto pki trustpoint DC2_TP
rsakeypair DC2_CA
crypto pki certificate map DC2_MAP 10
issuer-name co dc2.local
crypto ipsec transform-set DC2_TSET esp-gcm
mode tunnel
crypto ipsec profile DC2_IPSEC_PROFILE
set transform-set DC2_TSET
set ikev2-profile DC2_PROFILE
crypto ikev2 profile DC2_PROFILE
match certificate DC2_MAP
identity local dn
The correct IPSec profile would then be configured under the appropriate Tunnel interface on the HUB router.
The HUB would have 2 certificates, one for use on the DMVPN the other for use with the VTI.
The VTI spoke would only have 1 certificate, for authentication with the HUB.
02-21-2019 07:24 AM
Hi ,
Thank you for your help.it is very useful and i got alot of knowledge.
In my scenario i am using MS CA. VTI to DC1 is already deployed in production. Customers want to integrate DC1 and DC2 with different scenario.Please below file is actual design in production. It may very complicate for me.Very painful to solved.Please let me know your advice.Every sites (DC1,DC2,Branches)have two tunnel DMVPN tunnel and VTI tunnel.DC two have 2xVTI and 1 DMVPN as HUB.
02-21-2019 07:24 AM
Hi ,
02-21-2019 08:37 AM
Ok, I've figured out how to do it just using 1 CA on the HUB. If you configure the trustpoint on the DMVPN SPOKES with a unique value e.g. DMVPN, then on the HUB use the certificate map to match that to an IKEv2 Profile. For the VTI, just send the hostname of the device and match that against another certificate map.
HUB
crypto pki certificate map MAP_DMVPN 10
subject-name co dmvpn
crypto pki certificate map MAP_VTI 10
name co r5
match certificate MAP_DMVPN
match certificate MAP_VTI
DMVPN SPOKES
subject-name CN=R2.DMVPN
rsakeypair DC1_CA
VTI
subject-name CN=R5.lab.local
rsakeypair DC1_CA
02-21-2019 05:31 PM - edited 02-21-2019 05:35 PM
hi ,
In your advice do i need to generate rsa key with label right ?
and can i do without keypair ? becaus i cannot generate two rsa key in on router .
when i import my ca in router i saw below message and i am using below trustpoint.
crypto pki trustpoint my-ca1
enrollment terminal
serial-number none
fqdn cbtme-hub.crypto.local
ip-address none
subject-name cn=dmvpn
rsakeypair dmvpn
% The subject name in the certificate will include: cn=dmvpn
% The subject name in the certificate will include: cbtme-hub.crypto.local
02-22-2019 01:03 AM
You can define 2 rsa key pairs on a router, you just need the label and then to reference the keypair in the trustpoint.
rsakeypair DC1_CA
As it's creating an error don't add the FQDN, all we need for the matching is the subject name. The subject name needs to include something to uniquely identify itself - hence R2.dmvpn. For each of the dmvpn spokes the subject name would be different and includes it's router name e.g. r3.dmvpn or r4.dmvpn.
02-23-2019 11:26 PM
HI,
let me know can i do one trustpoint is without rsa key pair because my infra is already run with without keypair.
now i test with two CA ,two key pair and two trustpoint in lab. My dmvpn doen't up even thought without vti.
please see below attachment and let me know this what kind of error.
