configure & troubleshoot anyconnect
211
Beginner
DMVPN Phase II. Spoke to Spoke tunnels issues
My Current configuration spoke
interface Tunnel0
ip address 192.168.1.2 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication ISA-KEY
ip nhrp map multicast dynamic
ip nhrp map 192.168.1.1 real ip
ip nhrp map multicast real ip
ip nhrp network-id 1
ip nhrp nhs 192.168.1.1
tunnel source GigabitEthernet8
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile DMVPN-PROFILE
crypto isakmp policy 10
encr aes 192
hash md5
authentication pre-share
group 2
crypto isakmp key ISA-KEY address 0.0.0.0
crypto ipsec transform-set DMVPN-TRANS-SET esp-aes 256 esp-md5-hmac
mode tunnel
crypto ipsec profile DMVPN-PROFILE
set security-association lifetime seconds 120
set transform-set DMVPN-TRANS-SET
Hub:
interface Tunnel0
no ip redirects
ip mtu 1440
no ip next-hop-self eigrp 10
no ip split-horizon eigrp 10
tunnel source GigabitEthernet0/0/3
tunnel key 0
Its working properly after one month its down ? please help me for resolve this issue
Everyone's tags (1)
1 ACCEPTED SOLUTION
VIP Advisor
Re: DMVPN Phase II. Spoke to Spoke tunnels issues
All working and service down automatically. that means no configuration changed ?
what was the change ? links upgraded, hardware upgraded ?
Check basic check as mentioned below documents :
https://www.cisco.com/c/en/us/support/docs/security/dynamic-multipoint-vpn-dmvpn/111976-dmvpn-troubleshoot-00.html
https://community.cisco.com/t5/security-documents/dmvpn-on-spoke-troubleshooting-order-and-component/ta-p/3143396
Most of the errors you can see on both the devices, post the logs.
BB
*** Rate All Helpful Responses ***
2 REPLIES 2
VIP Advisor
BB
Highlighted
Beginner
Thanks For solution
