DMVPN Phase II. Spoke to Spoke tunnels issues
dhreeti.basu
My Current configuration spoke
interface Tunnel0
ip address 192.168.1.2 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication ISA-KEY
ip nhrp map multicast dynamic
ip nhrp map 192.168.1.1 real ip
ip nhrp map multicast real ip
ip nhrp network-id 1
ip nhrp nhs 192.168.1.1
tunnel source GigabitEthernet8
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile DMVPN-PROFILE
crypto isakmp policy 10
encr aes 192
hash md5
authentication pre-share
group 2
crypto isakmp key ISA-KEY address 0.0.0.0
crypto ipsec transform-set DMVPN-TRANS-SET esp-aes 256 esp-md5-hmac
mode tunnel
crypto ipsec profile DMVPN-PROFILE
set security-association lifetime seconds 120
set transform-set DMVPN-TRANS-SET
Hub:
interface Tunnel0
no ip redirects
ip mtu 1440
no ip next-hop-self eigrp 10
no ip split-horizon eigrp 10
tunnel source GigabitEthernet0/0/3
tunnel key 0
Its working properly after one month its down ? please help me for resolve this issue
balaji.bandi
All working and service down automatically. that means no configuration changed ?
what was the change ? links upgraded, hardware upgraded ?
Check basic check as mentioned below documents :
https://www.cisco.com/c/en/us/support/docs/security/dynamic-multipoint-vpn-dmvpn/111976-dmvpn-troubleshoot-00.html
https://community.cisco.com/t5/security-documents/dmvpn-on-spoke-troubleshooting-order-and-component/ta-p/3143396
Most of the errors you can see on both the devices, post the logs.
BB
balaji.bandi
BB
Thanks For solution
