Community Helping Community
227
DMVPN with Firewalls for IPSEC
Hello All,
I have a scenario that I want a secure connection between Headquarter and Branches using DMVPN. However, I need that the DMVPN functionality to be used only for tunnel concentration. For IPSEC I need to use firewalls following security team's instructions.
Is this scenario possible?
Thanks in advanced.
Luciane
Everyone's tags (1)
1 ACCEPTED SOLUTION
VIP Advisor RJI VIP Advisor
VIP Advisor
Re: DMVPN with Firewalls for IPSEC
I'm not 100% sure what you are trying to achieve, but DMVPN is not supported on Cisco Firewalls only on Cisco routers. Therefore you'd have to implement DMVPN with NHRP and IPSec on the routers, the routers could be positioned behind the firewall though, allowing through only the relevant ports/protocols.
2 REPLIES 2
VIP Advisor
Highlighted
Hi RJI,
It's right.
Thank you so much for your feedback.
Luciane Batista
Content for Community-Ad
FusionCharts will render here
