03-31-2012 12:25 AM
Hello Guys
i created three different Remote VPN connections with three different networks . i can make them one but for some reasons i don't mix all.
and iam using Cisco asa 5505 with Shrew Soft VPN software , so my problem is
- i connected Shrew soft remote vpn , if i try to connected another remote vpn connection this will not accept the second connection , so please can any one give me a remote vpn connection software that accepts more than one connection
Solved! Go to Solution.
03-31-2012 01:02 AM
Since you mention the ASA and the VPN I presume you are trying to connect by VPN Client to the same ASA?
Why would you want to have several VPN client connections at the same time? (Though I think that isnt even possible)
What are you trying to accomplish by these 3 different VPN Client configurations configured on the same ASA?
Isnt it just possible to configure one VPN Client connection to the ASA that would handle all the traffic of these 3 VPN Client connections?
- Jouni
03-31-2012 01:02 AM
- Jouni
