Easy VPN connection dropping...
j_friedrich
Hi guys,
     Is there a setting to keep the client connection open infinitely?  I don't want it to drop whether idle or passing packets.  The only time the connection should shut down is if the client manually closes the connection.
Ideas?
Thanks for everyone's help.
Jason
Eugene Korneychuk
Try to change vpn-idle-timeout to none under group-policy configuration.
Best Regards,
Eugene
