easy vpn connection drops
christfort
I have replaced our PIX with a new asa 5505 firewall. I use this firewall as easyvpn client to connect to head-office PIX unit.VPN tunnel establishes without problems but after 1 to 3 minutes the tunnel drops. When replacing the asa with the old pix, all is well. Is the ASA not able to connect to the pix or is my config wrong? output from show config attached.
Thomas
use :
debug crypto conditio peer [ip address of the vpn peer]
debug cry isa 127
debug crypto ipsec 127
attach the outputs at the time of the issue !
cheers .
5 Replies 5
Parminder Sian
Hi Thomas,
When does the connection drops, when the tunnel is idea or during traffic flow?
If it drops when no traffic is passing then try adding command "crypto isakmp keepalive 20"
Try this first and let us know how it goes.
Hope this helps,
Sian
Hi Sian,
The connection drops even when in use. We use the connection for remote desktops, and the connection allways drops after 2 to 3 minutes, even when working on remote desktop.
I tried your suggestion "crypto isakmp keepalive 20" all the same, however this didn't help.
Do you have any other suggestions?
Thomas
use :
debug cry isa 127
cheers .
Enclosed please find output from above debug commands.
Thomas
Hi Mohammad,
Have you had the time to check my above file? I still have not resolved the issue, despite I by accident pressed the 'Correct answer' link.
Thomas
