Beginner
easyvpn brakes remote access VPN session...
Hi there.
I using cisco 837 for incoming remote access  VPN connections with are working very well but I recently created one outgoing easy vpn connection and I have issue since that time.
As soon as easy VPN is up and established successfully I lost remote VPN access to internal subnet.
Where is :
Internal subnet: 192.168.172.0/24
remote VPN pool 192.168.24.2-6
Take a look at config attached and point me at missconfiguration please.
Thank you!
1 ACCEPTED SOLUTION
Hi Andriy,
It's more a limitation of the easy vpn technology rather than platform specific limitation.
On either routers or ASA firewalls, the platform can only be either an easy vpn server, or easy vpn client, but not both.
4 REPLIES 4
Unfortunately you can't configure easy vpn client on the same router as easy vpn server.
For your remote access vpn, the router is configured as an easy vpn server.
When you try to connect and establish an outgoing easy vpn, then the router itself becomes an easy vpn client.
Hence not supported.
You can configure the router as a LAN-to-LAN peer instead for the outgoing VPN connection.
Beginner
I see. Is it 837 series or all routers limitation?
Thank you Jennifer.
Hi Andriy,
Highlighted
Beginner
I see. Thank you Jennifer.
