02-25-2009 04:30 PM - edited 02-21-2020 04:09 PM
I'm trying to setup network using GetVPN instead of standard IPSec tunnels and was trying to get the KS and GM to be on the same box, is this possible? If so does somebody have a config example.
Andrew
Solved! Go to Solution.
02-25-2009 07:40 PM
Hello Andrew,
It is my understanding that KS and GM on the router is not supported.
Arul
*Pls rate all helpful posts*
02-25-2009 07:40 PM
Hello Andrew,
Arul
03-26-2009 05:42 PM
I just tried this on 3825s and 2811 routers running 12.4(24)T and it was still a no go. GETVPN works but it can be expensive to have multiple key servers. Configuration of policies and provisioning is simple and quick once you get it all operational.
Mike
