10-15-2013 09:14 PM - edited 02-21-2020 07:14 PM
Hello All,
An interesting issue, could be silly but I don't get it.. pretty simple configuration ..
Building configuration...
Current configuration : 1020 bytes
ip vrf CIT
rd 65500:100
interface Tunnel731
bandwidth 500000
ip vrf forwarding CIT
ip address 10.192.1.1 255.255.255.252
ip access-group cit-tunnel-protect in
ip mtu 1400
ip tcp adjust-mss 1360
load-interval 30
tunnel source Loopback0
tunnel destination 123.45.6.7
tunnel protection ipsec profile cit
crypto engine slot 1/0 inside
router bgp 65004
address-family ipv4 vrf CIT
no synchronization
neighbor 10.192.1.2 remote-as 65522
neighbor 10.192.1.2 activate
exit-address-family
end
int lo0
ip add 98.76.54.32 255.255.255.255
Extended IP access list cit-tunnel-protect
10 permit tcp 10.192.1.0 0.0.0.3 10.192.1.0 0.0.0.3 eq bgp
20 permit icmp 10.192.1.0 0.0.0.3 10.192.1.0 0.0.0.3
65000 deny ip any any
ping no problem, routing no problem but the problem is
when IKE1 session is intiated by the remote peer , bgp comes up no problem but if session is initiated by the local peer bgp won't come up ..
show cyrpto isakmp sa :
IPv4 Crypto ISAKMP SA
dst src state conn-id slot status
98.76.54.32 123.45.6.7 QM_IDLE 68011 ACTIVE ----- bgp comes up fine
123.45.6.7 98.76.54.32 QM_IDLE 68011 ACTIVE ---- bgp won't come up
I tried to remove the access-list , but I think same results were observed...
What am I missing here ?
Josh
10-16-2013 11:56 AM
Could it be the ACL; try adding the following:
15 permit tcp 10.192.1.0 0.0.0.3 eq bgp 10.192.1.0 0.0.0.3
BGP runs on TCP so it's kind of a client/server connection. One side uses random port >1024 to TCP/179 on the other side. You ACL matches depending on which BGP neighbor initiated the connection but does not match both cases...
Patrick
10-16-2013 02:05 PM
Thansk Patrick, I am seeing the same behaviour even with out the access-list. I am waiting to see how the remote router is configured . I don't see phase2 coming up when the local peer ( 98.76.54.32 ) initiated the session.
