407
Beginner
Help: Inside network access issue over IPSEC VPN
I have an issue accessing the inside network of my temple over IPSec VPN from my home network.  This only happens when I connect from my home networkusing Cisco ASA-5505. I have no problem accessing inside network of my temple if I use netgear router or Clear Hotspot instead of ASA-5505.  Here is the hardware detail:
At the temple, we are using Cisco ASA 5510 and we have so many IPSec site-to-site tunnels to different temple in the country.   Please see attached configuration for my home ASA5505.  I have verified that none of my home networks are overlapping the temple's networks.
Please help.
PatminASA-01# sh run
: Saved
ASA Version 8.2(5)
hostname PatminASA-01
enable password 1234xyz encrypted
passwd 1234xyz encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 3
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan3
nameif inside
security-level 100
ip address 10.10.105.254 255.255.255.0
ftp mode passive
same-security-traffic permit inter-interface
access-list NONAT extended permit ip 10.10.105.0 255.255.255.0 192.168.80.0 255.255.255.0
access-list NONAT extended permit ip 10.10.105.0 255.255.255.0 192.168.81.0 255.255.255.0
access-list ST-SSL standard permit 10.10.105.0 255.255.255.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
ip local pool IPP-SSL 192.168.80.100-192.168.80.110 mask 255.255.255.0
ip local pool IPP-SEC 192.168.81.100-192.168.81.110 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (outside) 1 192.168.80.0 255.255.255.0
nat (outside) 1 192.168.81.0 255.255.255.0
nat (inside) 0 access-list NONAT
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.10.105.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set TSSET-SEC esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map DYN1-SEC 1 set transform-set TSSET-SEC
crypto dynamic-map DYN1-SEC 1 set reverse-route
crypto map MAP-SEC 1 ipsec-isakmp dynamic DYN1-SEC
crypto map MAP-SEC interface outside
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 43200
telnet 10.10.105.0 255.255.255.0 inside
telnet timeout 10
ssh 10.10.105.0 255.255.255.0 inside
ssh timeout 10
console timeout 0
management-access inside
dhcpd auto_config outside
dhcpd address 10.10.105.101-10.10.105.132 inside
dhcpd dns 97.81.22.195 8.8.8.8 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
svc image disk0:/anyconnect-win-2.5.2014-k9.pkg 1
svc image disk0:/anyconnect-macosx-i386-2.5.2014-k9.pkg 2
svc enable
tunnel-group-list enable
group-policy GP-SSL internal
group-policy GP-SSL attributes
dns-server value 8.8.8.8
vpn-tunnel-protocol svc webvpn
split-tunnel-policy tunnelspecified
split-tunnel-network-list value ST-SSL
address-pools value IPP-SSL
webvpn
  svc keep-installer installed
  svc rekey time 30
  svc rekey method ssl
  svc ask enable default svc timeout 20
username pinesh password 1234xyz encrypted
username pinesh attributes
service-type remote-access
tunnel-group PROF-SSL type remote-access
tunnel-group PROF-SSL general-attributes
default-group-policy GP-SSL
tunnel-group PROF-SSL webvpn-attributes
group-alias PATMIN-Office enable
tunnel-group TG-SEC type remote-access
tunnel-group TG-SEC general-attributes
address-pool IPP-SEC
tunnel-group TG-SEC ipsec-attributes
pre-shared-key 1234xyz
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
Cryptochecksum:fcf9c9196cbe2c92222e127bdc8b30be
: end
PatminASA-01#
2 REPLIES 2
Does ipsec tunnel is coming up, if not past sh cry isakmp , sh cry ipsec, debu cry isakmp  and debug cry ips
If its up check the routing.
Pranesh
Highlighted
Beginner
Thanks Pranesh,
I haven't checked IPsec tunnel but I assumed that since I get successful connection to the VPN tunnel, the tunnel is up.  I have very limited knowledge about this; still learning the basics for CCNA certification.    The wiered thing is when I swap out ASA-5505 with home netgear router (at home), I don't have any problem accessing inside network at the temple.  Therefore, my assumption is something is wrong on my ASA-5505 config at home (the confg is pasted in intitial post.).  Please advise.
Again thank yo so much for your help.
