09-14-2012 06:43 AM - edited 02-21-2020 06:20 PM
09-14-2012 08:42 AM
Configuration on the ASA side is the same as in the following example:
http://www.cisco.com/en/US/products/ps5855/products_configuration_example09186a0080a9a7a3.shtml
I couldn't find any specific document for the RV042 but the GUI is intuitive, the only limitation on this side is that it can only build one SA (one slot for remote network and another for local network) so summarization must be used if you want this site to reach multiple subnets on the other network, buildling multiples might work but the results are variable and not supported.
Jonnathan
09-14-2012 09:35 AM
Greetings,
Please check Jonnathan's post (5 stars) to get familiar with the VPN configuration on the ASA.
On the other hand, here is nice doc:
Portu.
Please rate any posts you find useful.
09-14-2012 11:10 AM
Dear,
It is does not support 5525X, so what can i do?
Can u please send the doc for 5525X
Debabrata Das
09-15-2012 04:14 AM
please someboy help me ......
Debabrata Das
10-31-2012 07:58 AM
Hi Debudas,
I am sorry but I just saw this in my inbox.
The configuration provided does not depend on the platform, so you should be OK.
Please mark this post as answered if you do not have any further questions.
Thanks.
