Beginner
how to enable ISAKMP outside redundant interface ?
I'm in early stage of configuring a ASA-5520 box for remote VPN access w/ IPSec. I'm trying to enable ISAKMP on the "outside" interface (with vlan).
The outside interface would be the sub-interface 802.1Q for a redundant interface.
                   | === Gi0/0 === < --- > Switch #1
ASA-5520 ==           | +++ Redundant1 +++  Redundant1.251 (vlan251 outside)
                   | === Gi0/2 === < --- > Switch #2
Cisco Adaptive Security Appliance Software Version 8.3(1)4
Device Manager Version 6.3(1)
The command wouldn't succed since the interface does not have a "nameif" (as suggested by cisco.com). If I do set a "nameif" then the redundant interface will pass untagged packets.
The command is "crypto isakmp enable interface-name"
It would be: crypto isakmp enable Redundant1.251 but
Here is my run conf:
interface GigabitEthernet0/0
description Switch_#1
duplex full
no nameif
no security-level
no ip address
interface GigabitEthernet0/1
description *** not used ***
duplex full
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
description Switch_#2
duplex full
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
duplex full
shutdown
no nameif
no security-level
no ip address
interface Management0/0
description mgt-vlan
nameif inside
security-level 100
ip address 172.19.24.66 255.255.254.0
management-only
interface Redundant1
description Switch_#1_#2
member-interface GigabitEthernet0/0
member-interface GigabitEthernet0/2
no nameif
no security-level
no ip address
interface Redundant1.251
description vlan251
vlan 251
no nameif
security-level 100
ip address "outside_ip" 255.255.255.
1 ACCEPTED SOLUTION
Highlighted
Re: how to enable ISAKMP outside redundant interface ?
In this case, you would need to configure the "nameif" command within the subinterface of the redundant interface.
Example:
     nameif outside
Then, on the crypto isakmp command, you would be able to refer to the above "outside" interface configured via the nameif command:
crypto isakmp enable outside
Hope that helps.
Highlighted
Example:
     nameif outside
Hope that helps.
Beginner
Great ... but again, I read in some configuration guide "not to assign nameif" to a subint. I will try it.
No, you shouldn't configure the nameif command on the physical interface if you have subinterfaces under that particular physical interface purely because that trunk interface would not be tagged, hence it is not recommended to configure any interface settings under the physical trunk interface.
Ask the Expert- Webex Hybrid Services Solutions
