IPSEC Hub with Spoke Behind NAT device
Bonnie Mtengwa
I would like to setup an IPSec VPN, i have a challenge on how to do it because the Spoke device is behind a NAT device and also it uses dynamic IP addresses
can anyone point me to the right article that can help me to do this, or can help by the required commands on the HUb and Spoke Routers
thanks
Jennifer Halim
If it's dynamic IP on the spoke, you can only create dynamic-to-static VPN tunnel, and the VPN tunnel can only be initiated from the dynamic/spoke end.
Here is a sample config for your reference:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00801dddbb.shtml
Hope that helps.
