IPSEC PHASE 2 Problem
habibnoubissi
H everybody,
I have a problem with my ipsec phase 2 connexion, the phase 1 is active but phase 2 no, below are the output of some command like sh crypto session detail and sh crypto isakmp sa; please help me to troubleshoot this problem.
router#sh crypto session
Interface: FastEthernet0/0
Session status: UP-IDLE
Peer: 81.192.103.150 port 500 fvrf: (none) ivrf: (none)
      Phase1_id: 81.192.103.150
      Desc: (none)
  IKE SA: local 41.205.80.45/500 remote 81.192.103.150/500 Active
          Capabilities:(none) connid:1 lifetime:23:59:48
  IPSEC FLOW: permit ip 192.168.6.0/255.255.255.0 192.20.2.0/255.255.255.0
        Active SAs: 0, origin: crypto map
        Inbound:  #pkts dec'ed 0 drop 0 life (KB/Sec) 0/0
        Outbound: #pkts enc'ed 0 drop 75 life (KB/Sec) 0/0
router#sh crypto isakmp sa
dst             src             state          conn-id slot status
81.192.100.50  41.200.90.45    MM_SA_SETUP          1    0 ACTIVE
81.192.100.50  41.200.90.45    QM_IDLE              1    0 ACTIVE
8 Replies 8
Joe B Danford
Can you do the following?
show cry isa sa
In the output above you will see the conn id for the SA
clear cry isa
term mon
debug cry isa
debug cry ipsec
Run the debugs so we can see what is being passed. Also, do you have the configs for both end devices? Was this tunnel ever working? Make sure the transform-set and match ACL matches on both ends.
thank you very much for your reply,
the attached documents are my confir, the peer config (our partner) and the output of the debug command.
this tunnel has never work before we are setting it up now.
thank you once more
crypto ipsec transform-set vpn1 esp-3des ah-md5-hmac
crypto map vpnregeo 50 ipsec-isakmp
description tunel-to-M2M
set peer xxx.xxx.xxx.xxx
set transform-set vpn
match address 118
Your config appears to have an issue. You are reference TS Set VPN when you have VPN1 configured. Make the following changes.
no set transform-set vpn
set transform-set vpn1
Try again and see if this works.
Joe
I have tried what you ask me to do, but the problem remaining.
Excuse me Joe
if the peer router is not a CISCO router, do I have a particular thing to do in my CISCO router?
Sorry,
The TSet in your config reads
should be
crypto ipsec transform-set vpn1 esp-3des esp-md5-hmac
THANK YOU vey much Joe
that was the mistake, but see that the peer router is not a CISCO router, Ihave also set the lifetime for the two phases as it is set in the peer router, the two phases are up now.
Thanks to CISCO for such a plateform.
Excellent! No problem glad I could help.
